74 Users Online (73 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Massing Schedules
Mon, Apr 13, 2009 at 8:46:09 AM | Massing Schedules
naterfisher
4.5 Stars: 3 Votes
I am working on a master plan model that has several new buildings.  For the initial phases of the project I would like to have the buildings as simple masses that I can extract floor areas from.  This works great for buildings that have the same footprint on all floors but once the building mass begins to alternate per floor this becomes a lot more difficult to figure out how to get the floor areas from.  This is how I have been doing it:  I create a mass schedule where I include GFA as a field, create a field called levels where I input the number of levels of each individual mass and then I create a field with a calculated value called GFA per floor which is (Gross Floor Area / Levels).  And this field allows me to see the area per floor; however, it only works with masses that have the same footprint on all floors.  If you see the image attached you will understand the type of mass I would like to create where I can extract floor areas from.  I believe for this mass I am showing you it must be drawn as 2 masses, first mass would be the first 2 levels and the second mass would be the upper 5 levels then I can calculate the gfa per level; however, it will show up as 2 different buildings in my schedule.  I would like it to show up as 1 building with different floor areas per floor.
 Your help is greatly appreciated.
why my massing can't not be a solid?
Fri, Feb 11, 2011 at 8:26:42 PM
Massing
Mon, Jun 22, 2009 at 9:18:46 AM
conceptual massing...undulating roof shape
Thu, Jun 24, 2010 at 3:01:55 PM
Finding Massing Model
Wed, Feb 23, 2011 at 3:54:53 PM
>>>stuck with creating massing form in revit<<< HELP!
Fri, Nov 6, 2009 at 4:07:53 PM
Page generation time: 0.4381
