84 Users Online (82 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> PVC Conduit Family
Mon, Apr 13, 2009 at 7:59:48 AM | PVC Conduit Family
LTuss
I have a normal (pipe) family with center radius based on pipe diameter. Sizing is done through the csv file (lookup table)I need to add several types where the center radius is the same across the different diameters. These can be different family types. How to formulate the read center radius from the initial lookup table to the new types using one label as the constraint? Suggestions?
Wed, May 6, 2009 at 11:23:24 AM | PVC Conduit Family
Eddieboarder91
Eddieboarder91 Avatar
4 Stars: 8 Votes
well if you are using adsks fittings, theyre center radius is linked to the center to end dimensions, so if you simply change the center radius, the fitting will not be able to make the type. i strongly urge you not to use types in your fitting families only because when automatically drawing your piping it may not use the correct fiting based on what is defined in the pipe type. i think i know what you are trying to do, i had to create 59" and 60" radius bends for a specific application but i only needed 4" and 6" conduit.
www.allbimallthetime.blogspot.com
http://familyjewels.typepad.com/
Conduit to show hidden under slab
Wed, Aug 8, 2018 at 11:10:09 AM
Conduit
Tue, Jan 22, 2019 at 2:22:22 AM
Upgrade Your Home with Durable and Stylish PVC Shutters for Long-Lasting Appeal
Tue, Sep 24, 2024 at 6:05:35 AM
Defining conductor types in Conduit
Fri, Jan 4, 2013 at 5:12:26 PM
Lost as a goon.
Mon, Aug 6, 2018 at 2:24:10 PM
Page generation time: 0.9850
