Forums >> Community >> Newbies >> Mouse Configuration
Sat, Apr 11, 2009 at 2:12:39 AM | Mouse Configuration
lorderobla
Hi
Ive got revit architecture 2009 set up on my new laptop(Toshiba Qosmio G50). I have attached to my laptop a HP Optical 5 Button Mouse. When i use revit i find that the scroll wheel pans rather than zooms. Has anyone experienced this before? Ive been pulling my hair out trying to configure it correctly but have been unsuccessful. Any help is would be appreciated greatly.
Sun, Apr 12, 2009 at 11:36:50 AM | Mouse Configuration
4 Stars: 203 Votes
I'm sure the problem isn't in Revit, you must control that in "Control Panel > Mouse", check also, the manual (if you have) of the mouse to see how can you configure well....
Sun, Apr 12, 2009 at 12:33:40 PM | Mouse Configuration
erland73
erland73 Avatar
4.5 Stars: 85 Votes
"I have attached to my laptop a HP Optical 5 Button Mouse." Being a "special" mouse (5 buttons), you must have the driver for it....
Mon, Nov 9, 2009 at 6:08:53 AM | Mouse Configuration
lorderobla
Well i never did get to fix this problem. Have gone back to using Revit on my laptop today and still i cant get the mouse to zoom! Its frustrating beyond belief. Deadlines fast approaching...
Mon, Nov 9, 2009 at 7:06:27 AM | Mouse Configuration
Work with your mose settings on your system through your control panel.
Mon, Nov 9, 2009 at 9:14:16 AM | Mouse Configuration
TKennedy
4 Stars: 7 Votes
Try changing the middle button function. It's probable something like "Autoscroll" at the moment, see if there is a "Middle Button" option. Since you have a different mouse, you may have a separate control panel for it instead of the windows control panel.
Mouse Speed
Tue, Jul 19, 2011 at 4:48:43 PM
MOUSE PROBLEM
Mon, Nov 23, 2009 at 11:08:32 AM
system configuration
Fri, Aug 29, 2008 at 4:36:51 AM
MOUSE TOOLTIP
Tue, Nov 18, 2014 at 12:33:50 PM
plzzzzzz help with the whole syestem configuration...........everything......... [ 1 2 3 ]
Thu, Sep 4, 2008 at 10:21:00 AM
32
Page generation time: 8.2229
