41 Users Online (39 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> System family wall
Fri, Apr 10, 2009 at 9:33:58 AM | System family wall
Rhudson
So i've created a partition schedule and now i'm coming back to the plans to change the walls from generic to the types of the partition schedule. In the partition schedule I just used fill patterns and lines. So i added the components in the system family but I cannot figure out how to get the batt insulation to be inside of the metal stud. Is there anyway to make this happen? Or do I just not put the insulation then have to add it manually when it comes to creating my wall sections etc.?
Fri, Apr 10, 2009 at 10:16:03 AM | System family wall
3.5 Stars: 401 Votes
Batt insulation is shown as a repeating detaail and built in.  You add it to sections and plans if you want it but is not shown in the wall automatically.
Fri, Apr 10, 2009 at 10:56:30 AM | System family wall
Rhudson
Maybe I wasn't clear. When I add the metal stud and the insulation it is shown side by side not inside the stud. I want it to go inside the stud. How can I accomplish this?
Fri, Apr 10, 2009 at 11:34:04 AM | System family wall
No - you are not clear ... and you are still not clear.  If you are adding the insulation, put it where you want it!
Fri, Apr 10, 2009 at 11:48:42 AM | System family wall
Rhudson
You don't have to be rude. Please see attached jpeg to expain further. I want the insulation to be inside of the metal stud!
Fri, Apr 10, 2009 at 12:31:46 PM | System family wall
Not being rude - just tired of incomplete questions.  If you had started with "in my wall definitions"  or posted this image - any of us would have told you the answer very quickly.    When you say   "When I add the metal stud and the insulation it is shown side by side not inside the stud"  we can only assume that you mean you are drawing it.
I answered it as a wall definition in my previous post with "Batt insulation is shown as a repeating detail and built in.  You add it to sections and plans if you want it but it is not shown in the wall automatically."
You are describing what determines the wall thickness.... Your stud layer does that so ignore defining your insulation.
Fri, Apr 10, 2009 at 12:53:54 PM | System family wall
Rhudson
Ok, but thinking into the future when I create my wall details sheet; a section through the entire front wall of the building for example (not partition schedule sheet) I would like the insulation to show up. That's why I want to add the insulation in my wall definitions and have it fit inside the metal stud. I'm guessing by your reply that this is not possible, and when I go to create my wall sections I'll have to manually add all the insulation for each wall using lines. Is this correct?
Sat, Apr 11, 2009 at 9:19:21 AM | System family wall
coreed
coreed Avatar
4 Stars: 16 Votes
i would say you are correct for the most part in general.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Create a "Foundation Wall system family?"
Tue, Aug 3, 2010 at 9:50:54 PM
System Wall Family - Virtical profile HELP!
Thu, May 16, 2013 at 7:29:28 AM
System Family Names
Wed, Sep 9, 2009 at 10:32:42 AM
Timber curtain wall system
Wed, May 8, 2013 at 7:40:34 AM
Wall section system family
Mon, Nov 17, 2008 at 4:36:30 PM
Page generation time: 1.2134
