50 Users Online (49 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Changing the value of a Length parameter based on the value of a Yes/No paramete
Fri, Apr 10, 2009 at 9:21:56 AM | Changing the value of a Length parameter based on the value of a Yes/No paramete
tykomusic
Hello:
I have a length parameter called "Top Hole True" with a default value of 1/2".  I have another parameter, a yes/no parameter, called "Top Hole".
I want the value of "Top Hole True" (length parameter) to change to 1" if the "Top Hole" (yes/no parameter) is checked.
I thought the syntax would be as follows:
     Top Hole True = IF (Top Hole = 1, 1", .5"Winking
I have read that the number "1" equals "Yes" and that "0" equals "No".
The error is, "Improper use of boolean expressions."
I use Revit Architecture 2009
Thanks,
tykomusic
Fri, Apr 10, 2009 at 10:21:52 AM | Changing the value of a Length parameter based on the value of a Yes/No paramete
Top Hole True = If (Top Hole, 1", .5" )
Edited on: Fri, Apr 10, 2009 at 10:22:36 AM
Fri, Apr 10, 2009 at 11:37:51 AM | Changing the value of a Length parameter based on the value of a Yes/No paramete
tykomusic
Works great...thanks...
'Inconsistent units" error in parameter formula; length vs integer
Fri, Dec 13, 2013 at 10:37:05 PM
Can a Yes/No Parameter control a Length Parameter?
Thu, Mar 22, 2012 at 12:17:28 AM
Controlling Length of Floor Based Generic Model
Tue, Jan 4, 2011 at 12:11:59 PM
Visibility Parameter Formula based on 0.5m Lengths
Tue, Sep 6, 2011 at 4:59:08 AM
Length Parameter
Mon, Mar 17, 2008 at 10:44:56 AM
Page generation time: 2.7563
