31 Users Online (30 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Revit double counting objects in Schedule
Thu, Apr 9, 2009 at 6:19:13 PM | Revit double counting objects in Schedule
JI3ird
I have created a material takeoff to give me a "bill of materials" for foundation embeds, but for some reason, Revit is double counting the plates. I click on the plate in the schedule and then the "show" button and it pulls up the foundation with all of the plates highlighted. Once I am there, I manually count the plates myself and get exactly 1/2 of what Revit counts. Does anyone have an idea why revit Structure 2008 is doing this or what I am doing wrong?
Thanks,
Fri, Apr 10, 2009 at 9:46:29 AM | Revit double counting objects in Schedule
JI3ird
What is weird is when I delete one plate, the count decreased by 2.
Fri, Apr 10, 2009 at 10:13:07 AM | Revit double counting objects in Schedule
Better look at your family.  Is something nested?
Fri, Apr 10, 2009 at 9:43:31 PM | Revit double counting objects in Schedule
JI3ird
That is what I am think, but I don't see anything nested and I purged the file and get the same results. I inserted the one plate into a new project and it shows 2 plates in the material take off. I built the plate from scratch using extrusions and did not copy paste from another plate. I even copied the family and renamed it to a diffrent plate name and it is still double county.
Mon, Apr 13, 2009 at 7:16:27 AM | Revit double counting objects in Schedule
Post the plate family ... maybe it might help us to see what is happening.
Mon, Apr 13, 2009 at 9:38:21 AM | Revit double counting objects in Schedule
JI3ird
This is one of the plates that is double counting and I am having the troubles with. Thanks for the help, I really appreciate it.
Mon, Apr 13, 2009 at 10:25:45 AM | Revit double counting objects in Schedule
jarosa
jarosa Avatar
4 Stars: 5 Votes
Got me. I inserted it into a project and the quantities are correct. I selected all instances and the count is correct. I deleted one and the count change was by one. ??????
Does it make sense to delete all instances, purge from project and start over???
Mon, Apr 13, 2009 at 11:04:29 AM | Revit double counting objects in Schedule
I checked it out as well and it counts correct in a schedule but it does not count correct in a material takeoff.  What was interesting was that if I deleted the plate and left the studs, it counted as one but if I deleted the studs and left the plate, it still counted as two.
Something real strange here.
Mon, Apr 13, 2009 at 12:11:28 PM | Revit double counting objects in Schedule
JI3ird
I was using it in a material takeoff instead of a schedule. At first glance, a material take off looked easier to use. If you say you could do it in a schedual with out it doulbe counting, I will do it that way. Atleast I know I am not going crazy and have something configured screwey on my end.
Mon, Apr 13, 2009 at 1:09:32 PM | Revit double counting objects in Schedule
Hellfish13
3 Stars: 2 Votes
All I did was delete your plate in your family and replaced it with another extrusion and when I reloaded, the count when down to 1 per instance. Check it out. Also when creating families-sub-categories are fun and good to use Smile
Mon, Apr 13, 2009 at 1:58:19 PM | Revit double counting objects in Schedule
JI3ird
Thank you WWHub, JArosa, and Hellfish13 for all of your help. It is very much appreciated!
Revit Schedule double counting linked file
Thu, Dec 1, 2011 at 9:07:55 PM
Door width for double doors appearance in Schedule
Wed, Aug 5, 2009 at 10:49:53 AM
Room schedule input when working from an Architectural linked file
Wed, Mar 26, 2014 at 3:38:18 PM
walkthrough counting numbers on the right top of the image
Fri, Sep 12, 2008 at 6:31:39 PM
Manipulating the door schedule
Wed, Jun 26, 2013 at 10:35:33 PM
11
Page generation time: 2.6722
