135 Users Online (132 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Need Help Joining Rafter Ends in Revit Architecture 2009
Thu, Apr 9, 2009 at 11:29:33 AM | Need Help Joining Rafter Ends in Revit Architecture 2009
Berryjiveuptown5
Some of my rafter tails automatically join nicely.  But most of the time, the ends of the rafters do not join properly.  I've aligned the sides of the tails in plan view to make sure they are directly on top of each other.  Then, I've tried to Join the Geometry and, for the heck of it, the Beam Join command.  They are also the same size and family.  I know I could just copy the sides that are correct, but I'd rather figure out how to join them.
I've attached an image to show what I'm talking about.
Does anyone know how to fix this problem?
Fri, Apr 10, 2009 at 6:56:27 AM | Need Help Joining Rafter Ends in Revit Architecture 2009
4 Stars: 202 Votes
Did you try the "Roof Fascia" for that???
Fri, Apr 10, 2009 at 8:19:43 AM | Need Help Joining Rafter Ends in Revit Architecture 2009
Berryjiveuptown5
No, sorry those are two exposed rafter tails, not a roof fascia.  The roof fascia tool does somewhat fix my problem, but the other end of the rafters is more decorative.
Fri, Apr 10, 2009 at 11:09:58 AM | Need Help Joining Rafter Ends in Revit Architecture 2009
Berryjiveuptown5
Also worth mentioning, if I take the two rafters of the problem conditions and make a copy, the copy turns into the "desired effect" on both sides of the rafters.  I just wish I knew how or why it doesn't automatically join them.
Line Based Family Joining at Ends [ 1 2 ]
Mon, Apr 6, 2015 at 12:47:21 PM
16
Ceiling joist ends show above rafter line, how to trim?
Tue, May 19, 2009 at 6:33:41 PM
Problem aligning hip rafter on hip roof exactly where i want it. RAC 2009
Tue, Feb 10, 2009 at 6:37:32 PM
Autocad Architecture join the Revit Architecture Suite
Tue, Aug 19, 2008 at 9:14:56 AM
problem joining walls and structural columns in Revit 2009
Tue, Mar 16, 2010 at 6:27:20 PM
Page generation time: 2.3226
