86 Users Online (84 Members):
Forums >> Revit Building >> Technical Support >> brick skirt/foundation
126 Posts No Rating |
Just curious if you had to combine these two details how would you go about builing this in revit? I was thinking to maybe just use a family that is just continous brick i already have the vent and then create an in place family for the brick arch. Wondering if someone has another solution. Thanks,
working in 2008.
Image 1 - Do the columns and walls as walls and create the arch separately. I've done a similar thing in the past and modelled each brick as an extrusion and the mortar as one extrusion so that the bricks fan out. Image 2 - In place wall families - just extrude the detail and give it the correct material. Image 3 - Use in-place wall void extrusions to cut out the setbacks and apply the brick finish inside.
Brick or Stone Overhang |
Tue, May 8, 2007 at 11:40:16 AM
Slab Foundation |
Thu, Jan 31, 2008 at 1:59:46 PM
CUSTOM WALLS |
Fri, Feb 24, 2012 at 11:55:09 AM
foundation corner cleanups with setback |
Fri, Aug 26, 2016 at 11:54:14 AM
Wall Opening |
Mon, Oct 19, 2009 at 9:39:12 AM
Members: | 2042257 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
