80 Users Online (79 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Existing 12" wall w/4" brick-4" cavity-4" brick. Can't get plan brick to s
Wed, Apr 8, 2009 at 4:00:50 PM | Existing 12" wall w/4" brick-4" cavity-4" brick. Can't get plan brick to show
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
Only the outline of the wall shows in coarse, medium, and fine detail.  The sheet rock on either side of the metal stud core shows on the interior walls but the wythes of brick don't show in plan.  Is there a setting or view component that I have wrong?
Wed, Apr 8, 2009 at 5:08:40 PM | Existing 12" wall w/4" brick-4" cavity-4" brick. Can't get plan brick to s
wheelergc
Check your pahse filters.  If set to show complete it should show everything. Including all the details.
Thu, Apr 9, 2009 at 7:58:24 AM | Stumbled into the problem right after posting...................................
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
These walls are existing walls which, apparently, defaults them to outline only in plan.  Seems to me that graying out existing walls is OK, but why not leave the basic detail visible?  You were right.  It WAS a phasing problem.
CMU + brick wall- brick is NOT bearing
Tue, Dec 22, 2009 at 3:16:31 PM
Mixing of brick and block patterns and not aligning
Fri, Jun 23, 2017 at 9:40:17 PM
New Wall with Brick
Tue, May 26, 2009 at 9:36:25 AM
Brick Wall Recesses - How to properly model?
Fri, Feb 18, 2011 at 3:08:33 PM
Demo brick on brick/cmu cavity wall
Wed, Apr 1, 2009 at 12:24:22 PM
Page generation time: 3.9621
