Forums >> Revit Building >> Technical Support >> keyboard shortcuts file, where is it?
Ok, so i just transitioned to a new PC, Revit 2009 in windows vista x64. I go to the revit directory under program files / program, yet there is no keyboard shortcuts. Is there some other place that the keyboard shortcuts could be? And yes, i checked both program files and program files (x86)
from the help menu: Open the KeyboardShortcuts.txt file in a text editor. This file is typically located in the following directory: C:\Program Files\Revit Architecture 2009\Program\. The path may vary depending on your operating system or where you installed Revit Architecture. If it isn;t there, I would recommend just performing a search for "keyboardshortcuts.txt" in windows explorer. If you are using Vista, you have to go into the advanced options and tell it to search non-indexed and hidden system files. I'll assume the procedure is the same for x64.
Edited on: Wed, Apr 8, 2009 at 11:20:39 AM
nope, not there via regular access or search as i said in my first post, a advanced search reveals nothing also it dosnt help that the revit installed on here is installed in the x86 folder, but the shortcuts file should still be in there, but its NOT >
Is your windows explorer set to view hidden and system files? It HAS to be there, but it is a hidden system file. SO, you have to have the folder view settings to allow visibility of those folders and then when you search, you need to check the box that includes them in the search. Beyond that, can;t help. Sorry.
Lizard is correct - it is in a hidden file. You can unhide the files in explorer. Go to the properties of the 'Users' and unhide all the folders. The attached image shows the location on my computer, but yours will be different.
hi, i have the same problem and i cant find the file anywhere, not even in hidden files,, could somebody post there txt file for rac 2010?
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Daf do you have the new subscription update for 2010??? if so there is a new shortcuts manager that is very user friendly!
J. Allen Ball Revit Architecture 2010 Certified Professional |
RST 2010 keyboard shortcuts - TXT file vs Options list |
Thu, Feb 11, 2010 at 8:33:17 AM
Some Keyboard shortcuts not working? |
Tue, May 5, 2009 at 2:52:55 PM
Keyboard shortcuts |
Thu, Jul 3, 2008 at 11:14:44 AM
Looking for a few handy keyboard shortcuts |
Mon, Sep 27, 2010 at 8:21:51 PM
Keyboard Shortcuts Fails to Save or Import |
Mon, Jun 27, 2011 at 6:25:50 AM
Members: | 2115292 | Objects: | 23192 | Forum Posts: | 152320 | Job Listings: | 3 |
