75 Users Online (74 Members):
Forums >> Revit Building >> Technical Support >> David Blaine is in my model!
25 Posts No Rating |
I created a wall as an 'wall' in place family. Now if I don't have masses on it dissapears. So in order to see these walls I have to see all the other pink/purple masses in my model when i turn that mass cube on. What can I do to NOT make them a mass without recreating them as they were a b*tch to make, kinda complex. The one thing I noticed and the reason I did an in place family is that it gives you a volume of concrete for the wall. Creating a model mass and turning it into a solid will not do that.
Are you sure when you "Create-in-place" you choose the right category (WALLS)????
Too many people just use a "mass" without recognizing that they can set the category. Poor early choices will always get you down the road but we learn from our mistakes. You should be able to create a new in-place walls family by editing your mass and copy to clipboard your sketch and pasting into the new family... Two projects side by side work well to transfer this information.
![4 Stars: 19 Votes](/images/stars_4.gif) |
Also. in place wall families will give the volume in a schedule.
Glass Shower Doors |
Sun, Jun 15, 2014 at 10:10:58 AM
Helix from lines and points by David Light |
Sat, Feb 13, 2010 at 7:55:15 AM
Missing Element Properties Ribbon |
Fri, Aug 20, 2010 at 2:43:20 PM
Create a new family from a 'model in place' |
Tue, Jan 17, 2017 at 12:57:22 PM
Pella Designer Series window model |
Mon, Apr 20, 2015 at 3:29:36 PM
Members: | 2017174 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
