Forums >> Revit Building >> Technical Support >> Elevation Formula
4 Posts No Rating |
So i have started a project and was given different level heights after all my modelings was done. I came up with the idea of taking my elevation tag and creating a formula to add the additional height. Ie level 0'-0" needs to move to 100 so Elevation = (Elevation) + 100'. My problem is that I can't seem to get the formula to work! Can anyone give me a hand.
Would you prefer to just adjust the elevation (I can tell you how) or would you prefer the formula?
4 Posts No Rating |
Well the problem is that we are going to issue the drawings tomorrow and when moving if any info is lost we will not have the time needed to replace the info.
no need to move anything. I will write it up-give me a minute.
4 Posts No Rating |
Nope everything stays the same just i have to add 100;' to all elevations.
I just posted the steps in a tutorial in the tips & tricks section. Let me know if you have any issues, but it is pretty striaght forward. Cheers! http://www.revitcity.com/forums.php?action=viewthread&thread_id=15778
Elevation of receptacle with formula |
Wed, Nov 30, 2011 at 12:43:19 PM
Using schedule total in formula? |
Fri, Apr 4, 2014 at 10:29:50 AM
One family parameter has formula one has none |
Wed, Jun 25, 2014 at 1:05:54 PM
Parameter Formula |
Fri, Mar 5, 2010 at 12:09:09 PM
Level Annotation to show both Project and Geodetic Elevation |
Thu, Jun 28, 2018 at 1:42:28 AM
Members: | 2115336 | Objects: | 23192 | Forum Posts: | 152320 | Job Listings: | 3 |
