80 Users Online (78 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> thickend slab
Tue, Apr 7, 2009 at 8:53:55 AM | thickend slab
voglerb
I'm needing to show a thickend slab over a foundation bearing wall for a slab on grade.  I've tried modeling 2 slabs with slab edges and joining the edges but i can't get it to work.  Is there another work around to make this happen?  i have a 5" slab and it needs to thicken to 7-1/4" over the 8" foundation wall and tapper at a 1/10 slope back to the bottom of the 5" slab.
Tue, Apr 7, 2009 at 9:09:01 AM | thickend slab
You can use a floor edge sweep.
Tue, Apr 7, 2009 at 9:38:28 AM | thickend slab
voglerb
I can't seem to select the model line to add the slab edge.  Selecting the edge of the slab worked great.  I attached a drawing showing where i'm trying to add the thickend slab.  I've not worked with Revit very long.  I'm sure this is a simple task i just haven't figured it out yet.
Tue, Apr 7, 2009 at 9:40:49 AM | thickend slab
voglerb
ok,  here's the attached pdf.
Tue, Apr 7, 2009 at 10:24:24 AM | thickend slab
LIZARD2806
3.5 Stars: 7 Votes
You can do one of the following:
1.  Cut the slab at the wall where you need the slab edge, so you have an edge to grab.  You are left with two slabs that share an edge.  Add the slab edge as needed and join the two slabs.  CryingI did not check to see if there would be an issue joining the slabs)
2.  Create a solid extrusion that represents the thickened slab at that wall and join it to the slab.
HTH
Edited on: Tue, Apr 7, 2009 at 10:27:53 AM
Tue, Apr 7, 2009 at 11:35:08 AM | thickend slab
JMedina
I have a thickend slab 20'x20'x20' concrete cube. I want to cut it in half in Elevation view to create two separate 90 degree triangles that are on top of eachother? Having these two triangles to be overlaping each other and be two separate objects.
Or can I draw to separate Concrete triangles in Elevation view and place them on top of eachother to create a cube having them be two different objects? But I dont want to join geometry.
This is easy to do in Plan view but that is not the way I want to view the shape!
Tue, Apr 7, 2009 at 11:43:14 AM | thickend slab
LIZARD2806
3.5 Stars: 7 Votes
It sounds like you just want to create two solid forms (extruded triangles).  From your description, it sounds like that might be your best bet.
Tue, Apr 7, 2009 at 2:58:04 PM | thickend slab
JMedina
LIZARD2806 - Yes, I am. I tryed doing that by Modeling, Create, click on Site and I named it once I did that, I click on Solid Form- Solid Extrusion. I drew my two triangles filled in all my detail info that I need...Click finish Sketch and it works... The problem I am having is it doesn't give it a property name in the scroll down bar,  like if it was a Wall, Concrete Slab, Window etc... I need it to know that its an object.
Tue, Apr 7, 2009 at 3:07:03 PM | thickend slab
LIZARD2806
3.5 Stars: 7 Votes
Which scroll down bar?  Also, it might help if I knew what you were making...maybe a picture?
Tue, Apr 7, 2009 at 4:40:48 PM | thickend slab
JMedina
Lets see if this help, Solid Extrusion tool and just plan and simple Floor command tool...
Tue, Apr 7, 2009 at 4:43:22 PM | thickend slab
JMedina
Tue, Apr 7, 2009 at 4:45:43 PM | thickend slab
JMedina
Well I attached to pictures to my message but I don't see them there!
Tue, Apr 7, 2009 at 4:46:39 PM | thickend slab
#13
JMedina
Tue, Apr 7, 2009 at 4:52:24 PM | thickend slab
#14
JMedina
Problem when applying a footing to wall
Thu, Aug 23, 2012 at 1:52:55 PM
Slab tag positioning
Thu, May 14, 2015 at 8:43:39 AM
Revit 2010 Slab Edge Trouble
Mon, Feb 15, 2010 at 8:54:40 AM
Showing walls from the bottom of slab
Tue, Feb 9, 2010 at 10:40:41 AM
Inverted Tapered Slab
Wed, Apr 29, 2009 at 4:23:11 PM
Page generation time: 0.6570
