82 Users Online (81 Members):
Forums >> Revit Systems >> Technical Support >> Can't link with Central file
2 Posts No Rating |
Hi all!! Hope someone out there can help me! I’m running Revit 2009 on Vista Bussiness 64-bit and we are working on a very big project with worksets. My colleagues are running Windows XP 32-bit. When I create a Central file from the Vista PC as well as a local file, the synchronization between the files works seamlessly, but when we create a local file on the XP PC’s, they get errors saying that the central file has been moved or that there might be a network problem, which is not the case. Even if we go: “FILE, SAVE TO CENTRAL” and direct it to the central file it says that the path is invalid. When we repeat the same process other way round the Vista PC gets the errors. It seems to be related to either XP vs Vista or 32-bit VS 64-bit. If this makes any sense to anyone, PLEASE HELP!
![Eddieboarder91 Avatar](user_avatar/37222.jpg)
![4 Stars: 8 Votes](/images/stars_4.gif) |
it does actually make some sense just like when you try and remote into an xp machine from a vista machine...you either have to down grade or everyone has to upgrade...
www.allbimallthetime.blogspot.com
http://familyjewels.typepad.com/ |
2 Posts No Rating |
Thanks! I also thought that would be the case.
Link Central to Arch's File? |
Thu, Dec 17, 2009 at 11:35:39 AM
can't view file properties - central path |
Fri, Aug 21, 2009 at 2:34:53 PM
Central File & its Arch link - disappeared! |
Mon, Aug 29, 2011 at 2:54:22 PM
can't save as a central file |
Wed, Sep 9, 2009 at 2:35:47 PM
Audit central file - it's giving error |
Mon, Nov 30, 2015 at 9:43:50 AM
Members: | 2022302 | Objects: | 22973 | Forum Posts: | 152200 | Job Listings: | 3 |
