65 Users Online (63 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> question using view range
Mon, Apr 6, 2009 at 1:41:24 PM | question using view range-using revit structure 2009
workforlife
I have a sloping framed roof using steel joists. My view level is set to the low point of slope. In my view range the top range is set 5'-0", cut plane is set to 4" and bottom range is set to -2'-0". The cut plane is set to 4" because I want to show cmu wall hatching. The top range is set 5'-0" to show the steel joist sloping to high point of roof. The cut plane is showing the hatch in the wall but some of my steel joist are missing and the roof deck is being cut at cut plane. I thought the purpose of the top range is to show everything 5'-0" above the associated level just not cut.
Edited on: Mon, Apr 6, 2009 at 1:44:14 PM
View Range :Option Question
Fri, Nov 25, 2011 at 2:14:25 AM
view range on uderlay inconsistant with view range of plan view
Thu, Sep 4, 2008 at 3:48:11 PM
view range
Fri, Sep 7, 2007 at 2:28:04 AM
View Range
Tue, Aug 28, 2007 at 9:52:27 AM
new user question on ceiling plan view
Fri, Feb 16, 2007 at 7:31:49 PM
Page generation time: 1.8518
