Forums >> General Discussion >> Revit Project Management >> Is there anything Revit Architecture can do that MEP can't?
20 Posts No Rating |
I work for a CM modeling projects for estimating etc, I used to work in an architecture firm and only used Revit Arch. Do I need both now? Can I do everything I did in Revit Architecture in Revit MEP plus build the mech. systems? Thanks in advance...
Revit Architecture can slice bread..... I don't think MEP has that feature.
No It can, I tested it out... http://screencast.com/t/Otmf6yPLut
Edited on: Mon, Apr 6, 2009 at 5:57:21 PM
I stand corrected! It's true MEP has some architectural features but not all of them, just like structural has some and architectural has some structural.... blah blah blah. I dont think MEP can do some of the more complex architectural features, and I may be wrong but it probably doesnt have conceptual massing like revit 2010 architectural does. I have said in the past a Revit Construction with all disciplines (even civil?? yes civil) would be frikken sweet!
1 Posts No Rating |
Revit MEP Can't do: - Structural Beams, Columns, Bracing - VERY Annoying
- Host Sweeps and reveals (Walls, Roofs, Gutters, Slab Edges)
Might be a few others, but those are the most apparent AND annoying
mep isnt able to do the site components either. the conceptual massing is however part of 2010, as i understand from a white paper.
http://familyjewels.typepad.com/ |
oh nice! I wasnt sure if the engineer packages would get the conceptual massing, it is a pretty fun feature thats for sure. I suddenly find myself using Max and Sketchup a lot less
it certainly is cool but not cool enough to make me want to take over the world...just yet...
Linking Revit MEP, Structural Models into Revit Architecture |
Mon, Apr 23, 2012 at 4:00:04 PM
MEP and Architecture Intigration |
Fri, Sep 25, 2009 at 2:22:33 PM
Linking 3D Dwg files from AutoCAD Architecture to Revit MEP |
Thu, Aug 26, 2010 at 7:48:25 AM
MEP in Architecture |
Tue, Dec 6, 2011 at 12:05:18 PM
Creating Lighting fixtures for SEEK in Revit MEP or Architecture? |
Wed, Apr 16, 2014 at 11:38:24 PM
Members: | 2098609 | Objects: | 23170 | Forum Posts: | 152292 | Job Listings: | 3 |
