140 Users Online (137 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Plan view levels
Sun, Apr 5, 2009 at 3:48:29 AM | Plan view levels
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
i create another level in an elevation view
and i leave the "make plan view" checked
and a new level shows up in the browser..
i make the same level and i UNCHECK make
plan view.. now the level head stays black..
i decide later to make that level a plan view
and i cannot find how.. i select that level
and nothing in it's properties says to
make plan view.. ?????
Sun, Apr 5, 2009 at 5:37:57 AM | Plan view levels
tim123
4 Stars: 19 Votes
Go to Views, New, Floor plan.
Tue, May 5, 2009 at 2:27:19 PM | Plan view levels
fixybopixy
hi, i have a related question. My site has a grade change. The bottom portion is at 0' and the top portion is at 13'. So is there one building on the bottom, a plaza in between that will have stairs for the grade change, and a top level. how can i get the 13' level plan to appear in teh 0' level plan? i feel like its confusing having 2. see attached
Tue, May 5, 2009 at 2:31:33 PM | Plan view levels
wheelergc
VIEW>PLAN REGION
Draw your sketch and set the properties and you should have it.
Tue, May 5, 2009 at 3:15:04 PM | Plan view levels
fixybopixy
thanks! that made sense. u draw a "plan region" and put the level that u want to appear under view range in the properties list.
Converting associated levels to non plan view level
Fri, May 31, 2013 at 12:37:06 PM
Placing Electrical on Walls of different levels that are in same view
Thu, Mar 5, 2015 at 9:41:26 AM
Revit 2020 - Stairs not showing in plan levels
Sun, May 29, 2022 at 7:23:52 PM
Levels are missing - I tried all solutions on forums no result
Wed, Jan 30, 2013 at 10:57:44 AM
Revit 2013- negative levels wont allow me to place columns
Tue, Oct 9, 2012 at 6:53:00 PM
Page generation time: 1.2973
