59 Users Online (58 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> Creating disciplines?
Fri, Apr 3, 2009 at 12:54:02 PM | Creating disciplines?
cmreeves
Today is my first day switching to Revit and so far it's not going so well.  But I have made a tiny bit of progress but currently it is placing both Mechanical and Plumbing under the mechanical discipline.  My understanding is this will create an issue later if I want them on separate drawings so I'd like to make plumbing a separate discipline.  How do you do this?  If I'm making this more complicated than it needs to be, what are the alternatives?
Thanks for the assistance.
Fri, Apr 3, 2009 at 12:56:45 PM | Creating disciplines?
wheelergc
All you need to do it hide the elements you don't want to see by using view properties.
Fri, Apr 3, 2009 at 1:03:00 PM | Creating disciplines?
cmreeves
Thanks.  That seems simple enough but with only a few hours of Revit experience now, nothing is simple.
Fri, Apr 3, 2009 at 1:14:38 PM | Creating disciplines?
3.5 Stars: 396 Votes
After you have copied your plan and turned on/off what you want through VG settings (not view properties), select create view template from view.  That will give you a template you can always apply to the view to assure you have it set up correctly
Tue, Apr 7, 2009 at 10:39:14 AM | Creating disciplines?
Eddieboarder91
Eddieboarder91 Avatar
4 Stars: 8 Votes
also to add to what wwhub has said, dont under estimate the usefulness of filters...or workset visibility when you get there.
http://familyjewels.typepad.com/
Renaming or creating disciplines
Wed, Jan 7, 2009 at 4:30:38 PM
12
CD coordination of Revit among other disciplines using AutoCAD
Fri, Apr 12, 2013 at 2:05:46 AM
Disciplines: are all annotations (detail lines, symbols,etc.) architectural?
Mon, Mar 9, 2009 at 10:47:07 AM
Revit Spaces Elec VS Mech
Mon, Feb 1, 2010 at 9:52:50 AM
Other Disciplines Worksets
Fri, Feb 20, 2009 at 11:08:24 AM
Page generation time: 0.7671
