47 Users Online (46 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Revit 2010 Video Cards
Fri, Apr 3, 2009 at 9:38:46 AM | Revit 2010 Video Cards
sanio
Hi All!
 In the system recommendations for Revit 2010 it is stated that you will need a " Dedicated video card with hardware support for directX 9 (or later)
Does anyone know what would be a good card that fits this recommendation.
I am looking for application in an architecture office environment, which will exclude high-end gaming cards (unfortunately :-) )
Thanks & Best regards,
Sanio
Fri, Apr 3, 2009 at 11:27:27 AM | Revit 2010 Video Cards
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
I use both Nvidia Quadro FX series and ATI FireGL series workstation cards, both support directx9 and seem to support 2010 quite nicely, even my laptop Nvidia geforce 7950 gtxs seem to work ok. The performance isnt GREAT!! but it is improved.
Fri, Apr 3, 2009 at 11:50:27 AM | Revit 2010 Video Cards
sanio
Great! That means something like a geforce 8600gt 256mb, which retails at around 50$-60$ would do the job?
Fri, Apr 10, 2009 at 12:52:07 AM | Revit 2010 Video Cards
AlphaDDC07
AlphaDDC07 Avatar
4 Stars: 6 Votes
All design packages say that you have to have a dedicated graphics card. But from the reviews that I have read up on say that a shared graphics system will work.
If you do have the money for a dedicated graphics card, go for one that has accelerated graphics as this will improve the overall loading time of the graphics for any windows program.
Hope this info can help you!!
Twelve highlanders and a bagpipe make a rebellion.
Thu, May 28, 2009 at 3:04:34 PM | Revit 2010 Video Cards
jche
well, turns out ATI cards can give you a hard time if you want to use the DirectX acceleration - I tried 4 different ones in 3 different computers (could be a Vista problem) and had problems plotting (weird that it is connected) - elements were randomly missing which could be a serious issue as you can imagine.
Mon, Jul 27, 2009 at 12:38:30 AM | Revit 2010 Video Cards
edrikzs
does video cards reduce time in revit rendering ?
I'm going to buy a new pc soon...
here's what's on my list
 [Mother Board] - [LGA1366] Asus P6T Deluxe V2
 [Processor] - Intel™ Core™ i7 920 2.66 ghz 8mb 4.8 GT/s
 [RAM DDR3] OCZ 6gb (triple) ddr3-1333 pc3-10600 OCZ3G1333LV6GK (Gold Edition)
 [VGA PCIE] Palit GTS 250 1gb/256bit ddr3 (maybe I'll buy 2 if video cards would reduce rendering time)
 [HDD] Seagate 1tb/32mb 7200.11 (ST31000340AS) sata
 Cooler Master (RC-590) Centurion 590 atx w/o psu black
 HEC 700watts Cougar CM Series
 is this a good setup?
Edited on: Mon, Jul 27, 2009 at 12:40:30 AM
Tue, Sep 8, 2009 at 2:36:14 AM | Revit 2010 Video Cards
Ryguy3498
4.5 Stars: 2 Votes
The graphics card has nothing to do with rendering time. As soon as you hit "render", its all about the CPU. With that said, in Revit's model performance tech spec sheets, they clearly say that Revit will not use more than 4 cores for rendering. So getting a 2x4-core set up is worthless. Also, a quadro (or any workstation) card is not necessary. All you need is a current card with some decent specs. The graphics card is used more for when you are modeling in Revit and model regeneration.
revit 2010 video card
Thu, Apr 9, 2009 at 3:58:38 AM
video cards
Fri, Mar 6, 2009 at 10:24:12 AM
What is the name of the file that lists the accepted video cards in Revit ?
Thu, Sep 5, 2013 at 8:09:15 AM
Dual video cards
Wed, Nov 24, 2010 at 3:27:01 PM
Revit 2010 - Graphics Card - Nvidia Vs ATI
Mon, Jan 11, 2010 at 9:07:34 PM
Page generation time: 2.1197
