65 Users Online (64 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> copy with basepiont
Thu, Apr 2, 2009 at 11:26:47 PM | copy with basepiont
rebel
is there an option in Revit- copy with basepoint as in Autocad?
Fri, Apr 3, 2009 at 5:14:30 AM | copy with basepiont
MikeChan
3 Stars: 5 Votes
the answer is No, but any snap point of an element can be a basepoint while copy or move in Revit. Could you be more specific about your question? you might get a more clear answer you looking for.
Fri, Apr 3, 2009 at 7:59:19 AM | copy with basepiont
In addition to Mike's answer, there are some Revit copy/paste commands that are better than autoCAD's.
  1. When you are moving from view to view of the same area, use the copy / paste current view.  No need to locate - the baste will be in the same relative place.
  2. When you copy to clip board and paste in another view, REVIT will temporarily group the items together ... and until you accept the paste, you can align, move, or rotate them as a group.
  3. Check out the paste by level command as well.  Very usefull for multiple pasting on selecteive levels.
Need help with Copy/Monitoring
Tue, Apr 1, 2014 at 12:54:54 PM
i connot copy the wall on my COPY-MONITOR tools
Mon, Apr 11, 2011 at 11:51:17 AM
Copy Original Type Not Available in Copy Monitor Options Dialogue
Fri, Nov 6, 2015 at 2:16:28 PM
Copy/paste section to new project
Thu, Sep 10, 2015 at 10:21:14 AM
Copy VS Copy/Monitor
Fri, May 15, 2009 at 4:39:27 PM
Page generation time: 0.4638
