58 Users Online (57 Members):
Forums >> Revit Building >> Technical Support >> help - Toposurface & model
19 Posts No Rating |
I just recieved the site survey data from the surveyor which has the contour lines in 3D. I imported them into my model file but I have a problem...
I built the model at elevation 0'-0" and the lowest point on the survey is 93'-0".
I can't find where I can either reset the buildings base level to 93'-0" or move the survey model down. The survey doesn't move and there are no proerties. and I can't explode the survey.
Can anyone help me here?
thanks
Craig
One way is to place dimensions (in an elevation view or section) to every level and lock them all together. Then change the elevation value for the level that needs to be your new datum. This will move everything up accordingly.
Another (and better way) is to use: RELOCATE THIS PROJECT, check HELP, type Relocate and read through the info on this feature. This will allow you to have levels that report true sea level values as well as level elevations relative to another level. There is also a tutorial, though it's title escapes me at the moment.
Post edited on 2004-02-17 23:45:38
Thanks for your help. I wasn't able to do it with the relocate too, but was able to lock level dimensions and shift it that way.
Thanks.
Flat Toposurface |
Thu, Aug 3, 2017 at 8:58:49 AM
Toposurface&subregion problems |
Thu, Apr 16, 2009 at 1:47:06 AM
Toposurface in Elevations |
Thu, Aug 27, 2009 at 1:51:06 AM
Toposurface level wrong to Co-ordinates |
Tue, Mar 3, 2015 at 7:38:02 AM
In-place mass/toposurface intersection |
Fri, Jun 6, 2014 at 11:23:46 AM
Members: | 2042216 | Objects: | 23026 | Forum Posts: | 152216 | Job Listings: | 3 |
