50 Users Online (48 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Tips & Tricks >> Cement Fiber Board Panels
Thu, Apr 2, 2009 at 11:58:52 AM | Cement Fiber Board Panels
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
So I was wondering how others would go about creating an  exterior cement fiber board panel system that I could change the panels easily. The make up of the wall is as follows 5 1/2" wood stud w/ 3/8 plywood, 1 1/4" hat channel, 1 1/4 metal "z" channel, 5/16" cement fiber board panel.
I am thinking of creating the wall minus the 5/16" CMF then adding that on later using a curtain system..... thoughts?
Fri, Apr 3, 2009 at 6:21:17 AM | Cement Fiber Board Panels
MikeChan
3 Stars: 5 Votes
not a bad idea, but do you think using surface pattern will be better?
Fri, Apr 3, 2009 at 8:19:40 AM | Cement Fiber Board Panels
4 Stars: 202 Votes
Hi Alabaster, can you please (just for curiosity) put and image about that "Cement Fiber Board Panels"???? If it is what i think I use the Curtains wall too.....
Fri, Apr 3, 2009 at 11:46:51 AM | Cement Fiber Board Panels
alabaster2513
3.5 Stars: 25 Votes
ooops... that link  was bad
Edited on: Fri, Apr 3, 2009 at 11:49:34 AM
Fri, Apr 3, 2009 at 3:05:58 PM | Cement Fiber Board Panels
4 Stars: 202 Votes
NO, that's not what I was thinking, in this case I think I use the wall you post "5 1/2" wood stud w/ 3/8 plywood, 1 1/4" hat channel, 1 1/4 metal "z" channel, 5/16" cement fiber board panel.", split the wall where i want, create the "Reveals" with that "Void Profile" then use the "Paint" tool with the different color/material i want, I thought you are talking about other thing....
Fri, Apr 3, 2009 at 5:34:41 PM | Cement Fiber Board Panels
alabaster2513
3.5 Stars: 25 Votes
we started running into problems with the walls being split too many times. It would be nice if creating the reveals with the voids would create individual faces instead of still reading it as one. I am experimenting with the curtain system using a few different panel families. I'll post images of the end result with a quick video
Fri, Apr 3, 2009 at 5:49:52 PM | Cement Fiber Board Panels
MikeChan
3 Stars: 5 Votes
Curtain Wall certainly is a good option, just because you want to get those panels in different colour. If not, I think I will use wall reveal or Create a Face Based Family for the cut to archive the pattern.
If you choose to use Curtain Wall approach, I suggest you consider using Wall within Curtain Wall or Curtain Wall within Curtain Wall if you like. My suggestion is based on the concern of the amount of Curtain Grids.
Fri, Apr 3, 2009 at 5:57:45 PM | Cement Fiber Board Panels
alabaster2513
3.5 Stars: 25 Votes
my biggest problem with the face based voids was dimensioning them, Revit does not recognize the inner faces of the reveal for your dimension string.
Tue, Jan 9, 2018 at 2:20:09 PM | Cement Fiber Board Panels
markjraeburn
I don't think the reveal system works very well because you can't schedule the pannels to get numbers, sizes, thickness and colors. Solution needs to be flexible enough for different projects with different layout patterns, colors and panel type.
We are experimenting with using a Curtain wall system but don't have a good solution to share yet.
Hardie Board Panels
Wed, Sep 11, 2013 at 3:44:36 PM
Multiple Wall Material Question
Thu, May 12, 2011 at 5:04:01 PM
How to set the origin for hatch in revit
Fri, Sep 16, 2016 at 1:11:56 PM
curtain walls make like partition walls
Sun, Oct 26, 2008 at 2:03:29 AM
Cut curtain wall with opening behind
Wed, Nov 13, 2019 at 6:06:36 AM
Page generation time: 0.2773
