63 Users Online (60 Members):
Forums >> Revit Building >> Technical Support >> Wireframe lines showing up in Shaded 3D View
5 Posts No Rating |
I keep running into a problem any time I make even slight changes while in the 3D View. In both the shaded view and the hidden line view I get lines that should be hidden within the building which get progressively worse as I work in the file and eventually the entire view becomes wireframe. Most of the time I can close Revit and reopen the file and it is back to normal, all lines which should be hidden are hidden, but I very quickly run into the same issue again as I continue to work. This happens regardless of the detail level setting. Any ideas here?
![erland73 Avatar](user_avatar/39932.jpg)
![4.5 Stars: 85 Votes](/images/stars_4.5.gif) |
Delete that 3D view and create a new one....
5 Posts No Rating |
Thank you! That worked perfectly.
Revit model half shaded half wireframe |
Mon, Dec 2, 2013 at 11:30:03 PM
Shaded wall in Wireframe |
Mon, Jul 21, 2014 at 7:54:29 AM
In shaded View walls/roofs are showing material and lines behind them |
Tue, May 28, 2013 at 9:35:44 AM
DWG import shaded colors |
Sun, Apr 26, 2009 at 1:53:03 PM
3d model shows wireframe while in shaded mode |
Mon, Oct 3, 2011 at 4:27:32 PM
Members: | 2022349 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
