93 Users Online (92 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Adding Ramps as a Curve (riser must be straight line)
Thu, Apr 2, 2009 at 8:12:53 AM | Adding Ramps as a Curve (riser must be straight line)
OleBanshee
I am currently working on an Auditorium plan in Revit Arch 2009 and need to add the seating area.  The area is in an arc shape and i need it to slope from the ground floor up approx 2 feet.  I am trying to add in a custom ramp but every time i try i get a message telling me the risers must be straight lines.  Does anyone have any sugguestions on how a work around for this error or another way that would be possible to create a ramp for this plan?  Attached is a screen capture of the area that i am working with.  Any help would be greatly appreciated.
Thu, Apr 2, 2009 at 10:19:06 AM | Adding Ramps as a Curve (riser must be straight line)
afc4
3 Stars: 3 Votes
You can only have straight risers when working with ramps. You are going to have to make them out of stairs or use a mass to make it work.
Sun, Oct 13, 2013 at 4:04:42 PM | Adding Ramps as a Curve (riser must be straight line)
ArchStudentWIT
3 Stars: 2 Votes
Consider this:http://www.youtube.com/watch?v=5GaIarzxYPQ
Mon, Oct 14, 2013 at 7:56:28 AM | Adding Ramps as a Curve (riser must be straight line)
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
ArchStudent you posted this a couple times and some of the posts are REALLY old like this one thats over 4 years old.  If you want to post a training video or a tip there is a Forum section for that, otherwise its pointless to just go to a bunch of threads and throw a link in it.
Mon, Oct 14, 2013 at 6:36:40 PM | Adding Ramps as a Curve (riser must be straight line)
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
This area can be created using a sweep, or sweep blend if you want the end elevations to change. The attached is a method for developing streets and should work for this application.
HELP: making a Curve-Straight Stair
Fri, Jan 21, 2005 at 7:09:38 PM
Help : making a Curve Straight Stair
Tue, Nov 9, 2004 at 1:07:18 PM
Curved wall needs straight window opening
Tue, Sep 16, 2014 at 4:46:30 AM
Showing break lines with Ramps and Stairs
Mon, Jul 30, 2018 at 11:02:36 AM
TYPE SELECTOR for ramps and stairs
Thu, May 3, 2007 at 2:46:53 AM
Page generation time: 1.2246
