80 Users Online (79 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Unable to view RCP
Wed, Apr 1, 2009 at 3:23:43 PM | Unable to view RCP
shannoncarlson
Hi wonderful Revit masters!
I am using the student version of Revit 2009 to do a school project. I have a 3 floor building and am able to both work and view my RCP's on the first and second floors, however can not even pull up the RCP for the 3rd floor.
Does anyone have any suggestions as to why this is happening?
Thanks so much! You guys are great!
Wed, Apr 1, 2009 at 3:29:16 PM | Unable to view RCP
afc4
3 Stars: 3 Votes
is there a view created for the third floor? if not goto the view pull down--> New--> Ceiling Plan and check level 3. If that is not the case check the view range for the third floor.
Wed, Apr 1, 2009 at 3:44:51 PM | Unable to view RCP
shannoncarlson
There is an RCP for Level 3, I just can't get it to show up. How do I go about checking the view for that level?
Thank you!
Wed, Apr 1, 2009 at 3:55:12 PM | Unable to view RCP
afc4
3 Stars: 3 Votes
Right click in the view and goto VP( view properties) and the goto view range and see what the numbers are, Or you could just apply a view template to the view to get it back to a default RCP.
Unable to place lighting on RCP
Thu, Dec 16, 2010 at 1:39:43 PM
Fri, Jan 9, 2015 at 10:44:19 AM
Rooms in RCP
Tue, Mar 23, 2010 at 9:47:55 PM
see RCP on plan view
Mon, May 17, 2010 at 4:50:57 PM
view range wont adjust in RCP
Wed, Jan 31, 2018 at 3:44:21 PM
Page generation time: 1.3144
