46 Users Online (43 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Linear lights aren't linear at all?
Wed, Apr 1, 2009 at 12:41:02 PM | Linear lights aren't linear at all?
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Hello there,
I am trying to get a rendreing of our model and there is a soffit/light shelf in the ceiling that has linear lights in it to wash the ceiling.  When I put in a linear light that is 48" long, I render it and the light seems to only be about an inch and it is a hot spot...so I tried to array 64 lights total about 1' apart and I still get hot spots?!?!  I even tried to lock the linear light to the length and made it 60' long, still ZERO light showing up at the ends of the light or even a foot from the center of the fixture?
What's the point in linear lights if they don't exist?  I have to be missing something?  Anyone have any suggestions?
Thanks,
Lorne
Denver, CO
Revit Architecture
Thu, Feb 3, 2011 at 7:06:55 PM | Linear lights aren't linear at all?
Justinp
I'm having this problem too, are we doing something wrong?
Fri, Feb 4, 2011 at 3:36:27 AM | Linear lights aren't linear at all?
Dafpfy
3.5 Stars: 11 Votes
yes i would like some imput here to , i also have been strugling with linear lights, not rendering the width i have set in the properties.
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Fri, Feb 4, 2011 at 5:08:30 AM | Linear lights aren't linear at all?
4 Stars: 203 Votes
Select the light and on the properties palete, for "Light Source Definition" click Edit, then for "Emit from shape" click on "Line" and for "Light Distribution" select "Spherical" (not HemiSpherical), now render in "Medium" quality and check if this solve your problem.
Fri, Feb 4, 2011 at 1:38:22 PM | Linear lights aren't linear at all?
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
There is also the possibility that the rendering settings are too low, medium and higher settings are needed for lights to render correctly at their sources, if I recall.
Fri, Feb 4, 2011 at 1:54:02 PM | Linear lights aren't linear at all?
4 Stars: 203 Votes
Medium is enough to check if the light is working.
Linear uplights don't seem to be working.
Thu, Jun 25, 2009 at 10:19:27 AM
Linear lights rendered as spot lights
Thu, Dec 29, 2016 at 7:18:39 AM
Revit 2010 Linear Lights are only Illuminating in the Center
Mon, Aug 23, 2010 at 7:06:47 AM
Linear and Baseline dimensioning to centerlines of windows and doors
Wed, Feb 3, 2010 at 11:58:00 PM
Radial dimensions won't display but linear will?
Thu, Jan 23, 2020 at 2:09:02 PM
Page generation time: 0.4844
