75 Users Online (72 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> [Revit Structure 2009] Create 'Type Catalog' of existing family-types
Wed, Apr 1, 2009 at 3:59:07 AM | [Revit Structure 2009] Create 'Type Catalog' of existing family-types
Lenniepen
Hi there,
Is it possible to create a type catalog (.txt file) of existing family types. I have created 25 types in a new family and want to create a type catalog, so one can only load the wanted family-types in a project, instead of all the types.
I do not want to start from scratch to make a txt file.
I tried to export via ODBC, but it is disables while in a family. It is possible to export via ODBC in a project (where the family is loaded). When I export tot an Microsoft ACCESS-file I can find the loaded family and the family types, but can't find the parameters belonging to these types.
When I try to export the project (empty project with the self-created family loaded) via ODBC to an comma-seperated text file (.txt) I failes. I get the following error:
"Errors occurred while communicating with the ODBC data source: [42000] [Microsoft][ODBC Text-driver] Can not change the table ConstructionTypes. The database is read-only. (-1809)"    (translated from dutch)
 Thanks in advance,
Lennart
Wed, Apr 1, 2009 at 8:24:54 AM | [Revit Structure 2009] Create 'Type Catalog' of existing family-types
afc4
3 Stars: 3 Votes
http://whosafraidofthebigbadbim.blogspot.com/2009/03/revit-type-catalog-tip.html
Wed, Apr 1, 2009 at 9:18:18 AM | afc4
Lenniepen
Quoting afc4 from 2009-04-01 08:24:53
Thanks for your reaction, but it is not exactly what I'm looking for.
I want the already created family-types to show up in the type catalog, so I can select them too.
Also, the created types in the type catalog (in the .txt file) do not show up in the family editor in Revit when I open the family.
I guess it's just not possible?
Thanks in advance,
Lennart
Type Catalog
Mon, Mar 13, 2006 at 1:58:58 PM
Type catalog errors
Thu, Jan 19, 2012 at 2:07:19 PM
Family Type Catalog
Sat, Jan 10, 2015 at 9:14:21 PM
Suggestion Requiired - Types Catalog
Fri, Nov 27, 2009 at 7:30:49 AM
adding parameters to a family with a type catalog
Thu, Feb 19, 2009 at 11:10:21 AM
Page generation time: 2.6923
