97 Users Online (95 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Plane Views Range
Tue, Mar 31, 2009 at 10:29:02 PM | Plane Views Range
SirLyons
SirLyons Avatar
I haven't been using Revit but for only an week and have made great progress with it but now I have hit a road block.  I can not figure out why things are showing up above the plane cut line.  I did not have any problems with this till I started working on my second level.  The design was done completely using Revit.  I have messed with the plan view but I can't figure it out.  If anyone has any recomendations it would greatly be appreciated.
Sincerly,
-Michael
Fay Jones School of Architecture | University of Arkansas | Design Build | 4th Year
Wed, Apr 1, 2009 at 8:30:07 AM | Plane Views Range
afc4
3 Stars: 3 Votes
what is specifically showing up? The picture that ive attached shows the default settings for the view range.
Thu, Apr 2, 2009 at 10:01:17 PM | Plane Views Range
SirLyons
SirLyons Avatar
This is what I am seeing.  The lines that are appearing when I mouse over is what I am supposed to looking at but the ceiling and roof are in the way.
56342_What_appears.jpg56342_Lines_that_should_appear.jpg56342_View_Range_Settings.jpg
Thu, Apr 2, 2009 at 10:27:52 PM | Plane Views Range
SirLyons
SirLyons Avatar
never mind I figured it out.  Well not really I just deleted all the layers and remade them and it works now.
Thu, Apr 2, 2009 at 10:40:47 PM | Plane Views Range
SirLyons
SirLyons Avatar
never mind it is still messed up.
Mon, Apr 6, 2009 at 8:31:22 AM | Plane Views Range
afc4
3 Stars: 3 Votes
Make sure that you view depth is set to associated level and not unlimited.
view range top clip plane
Sat, Jan 24, 2009 at 7:56:32 AM
Plan Range - displayingn duplicated views
Wed, Aug 1, 2007 at 8:45:03 AM
View range queations
Mon, Jan 18, 2010 at 4:48:18 PM
View Range
Fri, Mar 13, 2009 at 5:05:42 AM
View Range > Cut Plane - Greyed out?
Fri, Sep 7, 2007 at 3:46:18 PM
Page generation time: 0.8150
