59 Users Online (57 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Netting Structure - complex / draped surface - any ideas appreciated
Tue, Mar 31, 2009 at 6:55:02 PM | Netting Structure - complex / draped surface - any ideas appreciated
ProperG
G'day everyone.  I'm struggling finding an appropriate way to model a netting surface in Revit Architecture 2009.  The one shown in the images was created as a topography with minimal thickness in archicad - and imported at a mass via autoCAD then each face converted to a wall in the massing tools in Revit - but this seems like an overly complicated work-flow.
 If I have four or five known points which do not lie in the same plane, is there some tool in revit which can create a surface that links them? Could anyone suggest an alternative way of (re)modelling sch a surface?
 I'm finding revit pretty limted and it's hard to sell it as the platform of the future to my employers when I have to use archicad, sketchup or even autoCAD to do what should be pretty simple operations.
 Any ideas would be most appreciated. Cheers, Pete
Tue, Mar 31, 2009 at 8:53:17 PM | Netting Structure - complex / draped surface - any ideas appreciated
BDerrick
3.5 Stars: 3 Votes
Hi Pete.  Sorry to say, I don't think Revit can form such surfaces.  I'm not too familiar with Revit 2010 but maybe they've added the tools you need.  I do know that 3ds max can easily make the surface you're looking for though.  Revit and 3ds max have a better relationship than the one you've described.  Hope you figure something out, good luck.
Wed, Apr 1, 2009 at 8:15:14 AM | Netting Structure - complex / draped surface - any ideas appreciated
afc4
3 Stars: 3 Votes
You have two options that you could try. The first one would be to create a mass and use voids to create that different edges and slopes on it, then you could add a face to the mass the represents the screen.( setting the correct transparency and surface pattern.)
 The second option is that you could just create a site and make that transparent. This way might be a little harder and wont be 100% correct but it would be easier to add topo points to make the odd shape.
 Hopefully this makes sense.
Wed, Apr 1, 2009 at 5:53:42 PM | Netting Structure - complex / draped surface - any ideas appreciated
ProperG
Thanks very much for your ideas guys.  I'll try and get into modelling it in 3DStudio Max or give it a go making it as pieces of topography.  The massing tool will be too complicated I reckon.
complex curved roof structure
Thu, Mar 12, 2009 at 1:11:50 PM
Pouring A Slab on A Complex Surface
Wed, Oct 14, 2015 at 12:26:33 PM
Creating A Complex Multi-Faceted Ceiling
Sat, Apr 13, 2013 at 9:15:41 AM
Issue with Dividing Surface for conceptual mass
Fri, Nov 11, 2011 at 12:45:48 PM
Civil 3d surface to revit topo surface
Thu, Oct 13, 2011 at 7:14:35 AM
Page generation time: 0.5724
