123 Users Online (122 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> keynote tag, crooked leader
Tue, Mar 31, 2009 at 2:20:34 PM | keynote tag, crooked leader
bert
Hi,
I created a keynote tag which could either display the keynote # or the text description. When using the description, my leader goes crooked as soon as I have an even number of lines in the description (it gets centered in between the lines of text). Is there a way to lock the leader to start on the top row of text? The way it's working now just looks dumb... (see attached).
Thanks!
Great Revit karma will come to you for answering my many questions.
using RAC-2013
Blog: Revit Templateer
Tue, Mar 31, 2009 at 3:13:20 PM | keynote tag, crooked leader
afc4
3 Stars: 3 Votes
are you using the keynote tag that came with revit? or is it something that you created?  Try using the one i attached to see if it acts the same way.
Tue, Mar 31, 2009 at 3:34:04 PM | keynote tag, crooked leader
bert
I made it a while back, but I believe I took the default Revit keynote tag and modified it. Your tag does work the way it should, so I think I'll modify that one to fit out standards.
Is there any way to get the leader to start at the top or bottom row?
Thanks for sharing and thanks for your help!
using RAC-2013
Tue, Mar 31, 2009 at 4:03:27 PM | keynote tag, crooked leader
afc4
3 Stars: 3 Votes
I just did a quick test on the one i sent you and it seems that if you move the text orientation from Top, Bottom, or middle within the family it causes the leader for the keynote to come in bent. Might be something that can be fixed with in the family.
Tue, Mar 31, 2009 at 4:44:36 PM | keynote tag, crooked leader
bert
I'll be trying this out tonight.
If I've sparked your curiosity, I've attached my tag. Feel free to give it a whirl.
using RAC-2013
leader line start locations?
Wed, Aug 3, 2011 at 11:45:30 AM
Keynote Tag defaulting to Category Tag
Fri, Jul 20, 2018 at 11:20:18 AM
Leaders on keynote tags
Mon, Mar 27, 2006 at 2:43:02 PM
Leader origin for multi-line keynote text
Thu, Jul 5, 2012 at 9:43:51 AM
Multi-Category Tag with horizontal leader lines - RAC 2012
Wed, Feb 15, 2012 at 4:29:15 PM
Page generation time: 1.9348
