42 Users Online (39 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Importing Cad Files
Mon, Mar 30, 2009 at 9:15:23 PM | Importing Cad Files
planbx97
4 Stars: 4 Votes
Hi, I'm trying to import some variouss CAD files in .DWG format into revit and make them into a family. Originally the files all came from .3ds files, so i had to import them into autodesk 3ds max design 2009 and then export them as .dwg files so i can import them into revit. Everything went smoothly until i realized that the individual pieces of the imported objects no longer had seperat materials, the whole object is just one plain color, Even though in 3ds max design 09 i assigned every piece a material. Are materials non transferable??? is there a better program to use?? am i doing this wrong??? help please! Thanks!
Mon, Mar 30, 2009 at 9:21:53 PM | Importing Cad Files
planbx97
4 Stars: 4 Votes
BTW im using Revit 2009
Tue, Mar 31, 2009 at 8:37:00 AM | Importing Cad Files
Each element in cad that has a different material needs to be on a different layer.  You then assign a material to that layer in Revit
Importing CAD to REVIT (vs. 2014)
Mon, Nov 24, 2014 at 4:03:44 PM
Importing DWG files
Wed, Jan 25, 2012 at 10:45:58 AM
REVIT'S POOR GRAPHIC DESPLAY WHEN IMPORTING AUTOCAD FILES
Sun, Sep 24, 2006 at 10:37:22 PM
Importing CAD 3D
Sat, Mar 7, 2009 at 7:26:46 AM
Importing 3D CAD Files
Tue, Apr 23, 2013 at 4:29:31 PM
Page generation time: 0.5244
