36 Users Online (35 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Extend floor into wall core, getting clean up correct (pic attached)
Mon, Mar 30, 2009 at 5:31:24 PM | Extend floor into wall core, getting clean up correct (pic attached)
rudyard
1 Stars: 1 Votes
When creating a floor on a brick veneer building, I use the option to have it sit on the structural part of the wall (the timber frame), I think it was called extend to wall core.  If I dont select this the floor incorrectly sits on the outer brick wall.
 Now the issues im having is that it doesn clean up correctly and the brickwork stops between the floor leaving a big gap as seen in the section below.  I have scribbled the correct detail I need in red.
There is also a problem in that the floor does not completely finish and close off over the timber wall (second red cirlce bottom right)
I really need this simple detail to be sorted, how do I go about getting it done?
Mon, Mar 30, 2009 at 6:18:38 PM | Extend floor into wall core, getting clean up correct (pic attached)
jarosa
jarosa Avatar
4 Stars: 5 Votes
as for the brick veneer, this has been covered a quite a bit in this forum. Here is one thread.
http://revitcity.com/forums.php?action=viewthread&thread_id=4357
Mon, Mar 30, 2009 at 10:36:53 PM | Extend floor into wall core, getting clean up correct (pic attached)
rudyard
1 Stars: 1 Votes
thankyou, I will try it out when i get home.
Tue, Mar 31, 2009 at 5:44:20 AM | Extend floor into wall core, getting clean up correct (pic attached)
tim123
4 Stars: 19 Votes
Detach the wall from the floor - it is currently attached to the u/s of the floor, and then use join geometry to cut the floor into the wall.
Wed, Apr 1, 2009 at 3:25:34 AM | Extend floor into wall core, getting clean up correct (pic attached)
rudyard
1 Stars: 1 Votes
tim123 thankyou that worked very easily and was nice and simple.
Whilst we are here, can I ask what is the reason to attached a wall to a floor then?  Why would this be useful if you need to deselect it for correct details?
Thanks again to all that helped me.
Wed, Apr 1, 2009 at 4:20:32 AM | Extend floor into wall core, getting clean up correct (pic attached)
tim123
4 Stars: 19 Votes
It can be very usefull for internal walls to attach to the u/s of the floor.
Edited on: Wed, Apr 1, 2009 at 4:21:35 AM
Wed, Apr 1, 2009 at 7:26:58 AM | Extend floor into wall core, getting clean up correct (pic attached)
rudyard
1 Stars: 1 Votes
Thanks again, so just to recap, you attach internal walls to the bottom of floors above but leave external walls as the outer skin needs to continue(not attach and stop at floor level) and the floor will cut the internal skin (effectively attaching it to the floor anyway)?
Clean wall join
Sat, Apr 20, 2013 at 3:30:49 AM
11
how to properly connect/clean up the wall
Mon, Aug 30, 2010 at 8:36:40 AM
Extending floor materials into wall core
Fri, Apr 24, 2015 at 9:01:39 AM
Walls extend to core boundary
Fri, Mar 17, 2006 at 8:16:47 AM
wall corners not joining clean
Wed, Dec 23, 2015 at 9:25:52 AM
Page generation time: 1.1669
