99 Users Online (98 Members):
Forums >> Revit Building >> Technical Support >> Adding Parameter to Array destroys it
11 Posts No Rating |
I'm trying to create a parametric array of shelves. I've created a family object (a shelf). Nested that into my new family and arrayed it. I locked the first element to the bottom ref plane, top element to top ref plane. If I just move the top ref plane the array follows it fine. If I put a dimension between the top and bottom ref planes and change the dimension it works. If I replace that dimension with a parameter it works, if I change the parameter to another parameter with a different value it works. But if I change the parameter value in the Family Types dialog box Revit complains and removes ALL contraints from the array. Why would changing a parameter value cause it to break?
Edited on: Mon, Mar 30, 2009 at 3:39:45 AM
maybe this link can help. look at post my Mr. Spot http://www.revitcity.com/forums.php?action=viewthread&thread_id=15581
Array Parameter within Family |
Thu, Aug 7, 2014 at 8:25:09 AM
Array Distance Parameter |
Thu, Apr 11, 2019 at 8:53:57 AM
Centering an Array Parameter within a Family (Wall Based) |
Fri, May 4, 2012 at 5:06:22 PM
Can't apply parameter to array number |
Fri, Dec 3, 2010 at 5:24:22 PM
visibility parameter for array group? |
Tue, Sep 11, 2007 at 3:11:24 PM
Members: | 2030567 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
