91 Users Online (89 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Model Pattern in Mirrored Groups
Mon, Mar 30, 2009 at 2:28:26 AM | Model Pattern in Mirrored Groups
Sandarch
I'm using Groups for modelling apartment units that are similar in a floor plan. The problem I'm facing is with Model Pattern used on Floors. When the Groups(apartment Units) are mirrored, the model pattern in the mirrored group goes awry. I have no idea why this is happening. Please see the attached image.
Tue, Mar 31, 2009 at 11:08:05 AM | Model Pattern in Mirrored Groups
Mirrored groups has always had problems in REVIT.  I would not use an applied model hatch.  Instead, let the material supply the hatch.  If you must ... then mirror the group without the hatch, then make a new group and hatch.
Fri, Apr 17, 2009 at 5:23:13 AM | Model Pattern in Mirrored Groups
Sandarch
thanks for your reply, wwhub.
I have actually used material with surface (model) pattern and not an applied model hatch.
mirrored groups
Tue, Sep 30, 2008 at 2:34:00 PM
Working with Model Groups
Tue, Dec 6, 2011 at 2:05:20 PM
Switches in a mirrored linked revit model
Fri, May 22, 2020 at 7:44:20 AM
moving a model group affects all instances?
Mon, Jul 17, 2017 at 10:16:37 AM
'Ungroup' causing fatal error in Revit Architecture 2011
Tue, Aug 24, 2010 at 3:31:35 PM
Page generation time: 1.2428
