16 Users Online (17 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> geometry memory size
Fri, Mar 27, 2009 at 10:37:52 AM | geometry memory size
hapyhour
How can I tell how much memory a object is taking.
What is a general rule or understanding of how to create geometry will minimal memory size.
Specifically, If I have 100,000 cabinet pulls in a file, will the creation of a simple geometry of the pull impact the overall file size, and what geometry is less space than another.
Fri, Mar 27, 2009 at 11:28:05 AM | geometry memory size
afc4
3 Stars: 3 Votes
You will just have to see what the size of the family is, im not sure if you can check the memory of an object. But i do know that if you have 100,000 cabinet pulls that are created in 3-d they will slow the model down alot more than just 100,000 objects created with lines. And if the object is already created in 3-d, you can turn off the solids in floor plans and elevations which will help.
I have enough memory but Revit doesn't agree about that
Sun, May 10, 2015 at 10:59:23 PM
2009 memory requirements
Thu, Jul 10, 2008 at 4:08:14 PM
x64 OS and 12 G of memory?
Mon, Aug 24, 2009 at 3:59:15 PM
Memory Hog
Fri, Jul 27, 2007 at 3:58:49 AM
Worksharing Monitor
Mon, Apr 28, 2008 at 3:30:37 PM
Page generation time: 24.7117
