70 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Closing open staircases
Fri, Mar 27, 2009 at 5:29:11 AM | Closing open staircases
spudisdabest
having trouble doing an exterior peice on a house ive designed..how do i seal off the underside of these stairs?
Edited on: Fri, Mar 27, 2009 at 5:30:12 AM
Fri, Mar 27, 2009 at 5:37:48 AM | Closing open staircases
4 Stars: 203 Votes
Well, I use for that a "Create-in-place" in the category walls and use the solid extrusion, create two extrusions in that elevation view, the first stop in the first wall and the second goes to the inner wall...
Fri, Mar 27, 2009 at 12:37:50 PM | Closing open staircases
afc4
3 Stars: 3 Votes
i would avoid using in-place families as they arent the best thing. the easiest way would be to just add a wall in the area you want to seal up and edit the profile so that it matches the stair profile. Plus wouldnt that be the correct way its done when your building it.
Sun, Mar 29, 2009 at 1:12:19 PM | Closing open staircases
spudisdabest
did i mention im a complete noob..
Sun, Mar 29, 2009 at 4:12:36 PM | Closing open staircases
jarosa
jarosa Avatar
4 Stars: 5 Votes
do as afc4 suggests. Create a wall beneath the stair. the trick is to create a section that looks a the side of the stair. create a reference plane that matches the angle of the stairs. select the wall. click edit profile on the options bar and align the top of the wall to the reference plane and bottom of the landing. this has been covered before in this forum. it's a good idea to search the forum or help first. you may up getting your answer quicker.
also as a note, you may want to check the stair properties. it looks like you are missing stringer(s).
john
Spiral Staircases
Mon, Nov 3, 2008 at 8:48:29 AM
Floating Staircases
Fri, Oct 31, 2014 at 1:09:23 PM
Changing staircases handrail into wall
Fri, Nov 21, 2014 at 7:30:50 AM
error message, unable to open revit file
Thu, Nov 6, 2008 at 9:12:13 AM
Closing Down a Project
Thu, Mar 13, 2008 at 2:51:54 PM
Page generation time: 0.3916
