Forums >> Revit Building >> Technical Support >> .MAX FILE IN REVIT??
![4 Stars: 1 Votes](/images/stars_4.gif) |
I WAS SENT A 3D MODEL THAT IS A .MAX FILE AND I WOULD LIKE TO BRING IT INTO REVIT. ANY SUGGESTIONS
![3 Stars: 3 Votes](/images/stars_3.gif) |
.max or a 3DS file? the only files that can be brought into revit are CAD,IFC, SKP, DNG and SAT. If its a #DS file you will need to save it as a 3-D CAD file to import it.
oK SO I CAN GET THE FILE INTO CAD AS A 3D MODEL AND I KNOW HOW TO IMPORT THE CAD FILE INTO REVIT AS A 3D, BUT MY QUESION KNOW IS HOW DO I ATTACH MATERIALS AND ETC.... 3D MODEL
What kind of "3D MODEL" are you trying to import???? cars, plant, the whole building, what??? what i can advide is, and i just did several posts about this issue, if you are import (for example) a CAR or a PLANT so create a new family in the right category (CAR=Entourage Family, PLANT= Planting Family......), then import the "3d Model" into the family, after this you have two choises, ONE-go to VG and you have there "Imported Objects" there you change the material, color. OR the SECOND- in Settings>materials you gonna see several "Render ###,###,###" this is the colors you have in CAD, so what I do is change those "Render ###..." (one by one) by the respective material i want and I change the name so in this way (change name) i know when i load that family tho the project what material i want to change (if i need) for example: "Car_Doors", "Car_Glass".....
1 Posts No Rating |
i have done many times but when render the material always grey , you can make the material for my tree? Thanks!!!
Send me the file...
Ensure the different materials have their own layers in max. - import dwg file
- go to settings-->object styles-->Imported tab
- you'll see you layers here.
- in the materials column apply, create or edit the material you wish to apply to each layer...
This is my preferred way of applying materials to cad imports as you don't have to keep the materials with ambiguous names...
Regards,
Chris.
Exporting FBX file from Revit to 3Ds Max |
Wed, Sep 30, 2020 at 1:36:49 PM
Revit FBX causes 3DS Max to crash |
Wed, Aug 10, 2016 at 6:02:27 PM
Revit bring into 3ds Max [ 1 2 ] |
Sat, Dec 25, 2010 at 6:24:33 PM
17
Revit to 3d Max FBX [ 1 2 ] |
Wed, Dec 1, 2010 at 8:52:13 PM
17
problems with Revit 2013 in 3ds Max! |
Fri, Dec 14, 2012 at 4:25:44 PM
13
Members: | 2022349 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
