48 Users Online (46 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> split level homes
Mon, Feb 16, 2004 at 3:32:37 PM | split level homes
Bimman
Bimman Avatar
1 Stars: 2 Votes
i have a 5 level split, going from basement to 2nd floor. what i am running into is my cut plane on my second floor(5 th level) will not show my will not show my windows form my owner's suite level(4 th level). in my 2D drafting days with this plan we only had 3 sheets shownig all the levels. foundation(level 1) by itself, first floor(3rd level) would have all the lower level(2nd level) info on it. tthe second floor(5th level would have all the owner's suite(level 4) info on it. my question is in revit would i now need 5 different sheets to show all the info that was on 3 sheets before . or do i adjust view range to what i need to show. i hope i made so sense here. Thanks
PWD
Mon, Feb 16, 2004 at 4:49:20 PM | RE: split level homes
HCSL
If you are using R6 you can use the new PLAN REGION feature. You can find it under VIEW/NEW/PLAN REGION. It allows you to define different cut plane elevtions for portions of your plan. I won't go into detail (the help file/tutorial is great, as always). This tool is designed for just this sort of thing. Before you ask... no, it doesn' twork in section views, only in plan.
Tue, Feb 17, 2004 at 7:04:25 AM | RE: split level homes
Bimman
Bimman Avatar
1 Stars: 2 Votes
new to me, i didn' t know about that feature in 6. thanks for the tip.
PWD
View Range or Cut Plane Settings for Split level and Cape style
Fri, Jul 6, 2012 at 8:19:55 AM
Level Split
Wed, Feb 1, 2012 at 4:04:32 PM
Creating A Split Level Home *Need Help*
Tue, Sep 13, 2005 at 12:33:49 PM
How do you treat split levels or minor level changes?
Mon, Jun 26, 2006 at 10:40:02 PM
Windows not showing in split level floors -?
Thu, Jul 24, 2008 at 11:22:13 AM
Page generation time: 1.7723
