52 Users Online (51 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> site development
Thu, Mar 26, 2009 at 10:30:41 AM | site development
jpowers
Is there a way to put a chainlink fence onto a sloped site?
Thu, Mar 26, 2009 at 3:20:07 PM | site development
afc4
3 Stars: 3 Votes
i dont think that you can. The only thing i can think of is to use a wall( made to look like a fence) and change the profile to match the slope. You could also use a railing but it doesnt see the site as an object it can host to.
Thu, Mar 26, 2009 at 3:23:44 PM | site development
4 Stars: 203 Votes
"chainlink fence" - Images of what you want....
Thu, Mar 26, 2009 at 3:28:07 PM | site development
afc4
3 Stars: 3 Votes
http://hokcadsolutions.blogspot.com/2008/10/revit-timber-lattice.html
not chainlink but this is how to make lattice
Thu, Mar 26, 2009 at 3:28:34 PM | site development
erland73
erland73 Avatar
4.5 Stars: 85 Votes
I think something like this Typhoon....
Thu, Mar 26, 2009 at 3:40:36 PM | site development
4 Stars: 203 Votes
Well, the simple way it's like AFC4 says, it's quick and simple but if you want that in 3D use Curtain Wall....
Thu, Mar 26, 2009 at 3:46:23 PM | site development
afc4
3 Stars: 3 Votes
what if you made a 1/4" wall that was transparent and had a diagnol cross pattern attached to it.
Thu, Mar 26, 2009 at 3:53:52 PM | site development
4 Stars: 203 Votes
Yeah AFC4, that's what i said, that is the quick and simple way to do this, create a thin wall with the image like Erland post (for example) and in the properties of the material, in the "Bump" you can apply the "Mask" (alpha channel) or you can also use a material with the "Cut-Out"....  BUT if he/she want that in 3D, well I use curtain wall to do that.... that's my modest opinion...
Thu, Mar 26, 2009 at 3:57:31 PM | site development
afc4
3 Stars: 3 Votes
see attached, works the same way and can be seen in 3-d
Thu, Mar 26, 2009 at 4:01:50 PM | site development
4 Stars: 203 Votes
Yeah, AFC4, I know that, that's what i said.... we put here solutions to the issues/problems and he/she decide what is the best way to go on, always depend what someone need/want.....
Thu, Mar 26, 2009 at 4:05:19 PM | site development
#11
afc4
3 Stars: 3 Votes
so then what do you mean by "but if you want that in 3D use Curtain Wall...."
Thu, Mar 26, 2009 at 4:13:27 PM | site development
#12
4 Stars: 203 Votes
"so then what do you mean by "but if you want that in 3D use Curtain Wall...." - Well, if I Need to create a (for example) a "Section View", if i use a simple wall i only gona see the "panel" I can't see the details in that, then i must use "Filled Regions" and so one to do that, if I use the curtain wall I have that detail at once, i hope you understand my bad english... LOL
Fri, Mar 27, 2009 at 8:09:32 AM | site development
#13
afc4
3 Stars: 3 Votes
makes perfect sense. thanks
Linking the same revit model into a site with different RL's
Wed, Sep 12, 2007 at 9:14:42 PM
Multiple units on sloping site
Tue, Feb 21, 2006 at 3:29:29 PM
Site Work
Thu, May 1, 2008 at 11:45:05 AM
Retaining walls on site
Tue, Apr 15, 2008 at 6:02:54 AM
Development for Section box command in Revit
Fri, Apr 20, 2012 at 3:50:03 PM
Page generation time: 0.6411
