27 Users Online (26 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Channel glass in revit architecture?
Thu, Mar 26, 2009 at 10:12:07 AM | Channel glass in revit architecture?
snoochie
I need channel glass similar to the one like in Steven Holl's Pratt institute in revit. Does anybody know how can I get it in there?thanks
Thu, Mar 26, 2009 at 1:36:48 PM | Channel glass in revit architecture?
afc4
3 Stars: 3 Votes
to me that looks like you could just use a curtain panel and change the boundary of it to get the desired shape and panel sizes.
Thu, Mar 26, 2009 at 1:53:28 PM | Channel glass in revit architecture?
snoochie
i actually did that, but im not really sure now how to assign material to it so I could render
Thu, Mar 26, 2009 at 2:01:45 PM | Channel glass in revit architecture?
afc4
3 Stars: 3 Votes
well to add materials to a to the mullions you will need to select the mullions and create a new type and then add a new material. to do this
Click the Mullion
Go to Element Properties
Click Edit/New
and here you can change the material.
It works the same for the glass.
Thu, Mar 26, 2009 at 2:30:10 PM | Channel glass in revit architecture?
snoochie
i couldnt really find how to change glass material in type properties. and i also went to Settings->Materials, and change material and transperency level from there, but it didnt seem to work...
Thu, Mar 26, 2009 at 2:36:42 PM | Channel glass in revit architecture?
4 Stars: 203 Votes
Go with your mouse to the glass panel, then with the "TAB" key click several times until you see the panel is selected, then pick with the mouse, go to the properties and you have there the glass material where you can change...
Edited on: Thu, Mar 26, 2009 at 2:37:57 PM
Channel Glass
Fri, Nov 30, 2007 at 4:06:53 PM
Channel Glass/How to locate once loaded in project
Sun, Jul 7, 2013 at 6:45:01 AM
Glass Channel problem in rendering, why does it show grey?
Thu, Feb 2, 2012 at 6:54:43 AM
using TGP Profilit channel glass file
Fri, Nov 22, 2013 at 7:51:50 AM
Unable to create a wall by face
Thu, Dec 16, 2010 at 3:18:42 PM
Page generation time: 3.7414
