71 Users Online (69 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Zero thickness wall layer
Thu, Mar 26, 2009 at 9:16:17 AM | Zero thickness wall layer
BobbyCJones
My overall goal is to have a wall finish layer that allows me to capture square footage in a table, allows voiding areas of the finish, does not show in plan view, but does show hatching in elevation and 3D views.
Our current wall family with a siding finish has a 1/2" thickness to the siding.  It does everything we want, except that it shows in plan view.
I can assign the siding layer to have a membrane function, and give it a zero width, but I can't get hatching to show on a membrane layer and I'm not sure how I could void out the membrane layer on areas of the wall where I don't want the finish.
Any thoughts?  Thanks.
Bobby C. Jones
Fri, Mar 27, 2009 at 7:06:17 PM | Zero thickness wall layer
cganiere
cganiere Avatar
Make the finish layer smaller (1/32"Winking. Don't use a membrane layer because the more you use thing for reasons that they were created the more incompatable your file becomes for future users.
Christopher Ganiere, NCARB, LEED AP
www.developmentone.net
Skype: ArchitectCRG
Sat, Mar 28, 2009 at 4:36:06 PM | Zero thickness wall layer
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Sounds like the only "correct" way would be to model the finish layer as its own wall.
  • You can then give these walls a property as finish to enable you to filter them from displaying in plan
  • They'll show fine in elevation
  • Can get all there areas
  • simply join them to the main wall and they'll automatically inherit the same cutouts for windows and doors...
HTH.
Regards,
Chris.
Mon, Mar 30, 2009 at 7:22:16 AM | Zero thickness wall layer
BobbyCJones
Hey guys,
Thanks for sharing your ideas.  I have tried assigning the finish a very small width, but the smallest that I could get was 1/16", just enough to ensure that somebody would snap a dimension to the finish instead of the stud and sprinkle the plan with 1/16" dimensions.  Ever the optimist, I started with 1/256" and doubled the number until Revit took something, which ended up being 1/16".
And thanks for the tip about joining the walls.  That's going to come in very handy.
Bobby C. Jones
Errors using Membrane Layer: zero / non-zero thickness
Wed, Aug 7, 2013 at 6:08:50 PM
change layer thickness
Tue, Oct 27, 2015 at 7:51:57 AM
How to control a single-layer wall?
Wed, Apr 28, 2010 at 2:39:50 AM
Kenoting a Membrane Layer (0" thickness)
Sat, Feb 12, 2011 at 12:23:27 PM
Wall Thickness in Type Parameter
Fri, Jun 1, 2018 at 7:39:15 AM
Page generation time: 1.6616
