Forums >> Revit Building >> Technical Support >> High Quality Rendering Error
Thu, Mar 26, 2009 at 8:17:24 AM | High Quality Rendering Error
dkclayton89
Ok. I am trying to render a very simple building. When I render it as a "Draft" it works fine. But if I change that to a "High" quality rendering it turns black and says that it cannot find the correct materials. Does anyone have any suggestions as to how to fix this? It is very frustrating. Thanks!
Thu, Mar 26, 2009 at 9:01:09 AM | High Quality Rendering Error
afc4
3 Stars: 3 Votes
have you tried any of the other settings? do you get the black screen or will it render? also what type of rendering is it? are there lights and are they turned on?
Thu, Mar 26, 2009 at 11:24:49 AM | High Quality Rendering Error
dkclayton89
Sorry I didn't provide more detail:
 It is an Exterior Rendering. The only thing that will render is the sky/background. The building and landscape all turn black. I have tried several settings and I can't seem to get it to work in any of them!
Thu, Mar 26, 2009 at 12:37:29 PM | High Quality Rendering Error
dkclayton89
Thu, Mar 26, 2009 at 1:30:47 PM | High Quality Rendering Error
afc4
3 Stars: 3 Votes
im not really sure what could be causing this. The only thing i know of is that sometimes have an exterior pattern on a wall will sometimes turn black bc the view is to far away. Also sometimes the shadows do some weird things. Try creating a new view thats a little closer and see if that works.
Thu, Mar 26, 2009 at 2:33:44 PM | High Quality Rendering Error
4 Stars: 203 Votes
Wierd, it render in "draft" but not in "High or Best"???
Thu, Mar 26, 2009 at 3:11:23 PM | High Quality Rendering Error
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Have you tried to render it on another computer in order to check whether it is a hardware issue or something about your Revit installation?
Problems with Best quality nighttime rendering.
Tue, Dec 4, 2012 at 8:32:13 PM
Exterior/Interior Lighting in High Quality Rendering
Wed, Mar 18, 2015 at 4:16:33 PM
How to get high quality output in revit2011
Fri, Feb 8, 2013 at 1:22:16 PM
11
Rendered products are not a very high quality
Fri, Mar 6, 2015 at 1:52:00 PM
Rendering Performance [ 1 2 ]
Wed, Feb 15, 2012 at 6:14:36 AM
16
Page generation time: 16.1266
