Forums >> Community >> Newbies >> SLAB AND PAD
33 Posts No Rating |
What is the difference here? I created a slab and now what is the pad tool do?
----------------------------------- IMAC 3.06GHZ,MACOSX 10.5.6 with WINDOW XP PROF, REVIT ARCH 2009,AUTOCAD 2009,VECTORWORKS 11.0,ARCHICAD 7.0,LEED AP. |
SLAB: A section of solid concrete pavement, roof, or floor. Slabs can be used as a combined floor and foundation system. PAD: You can add a building pad to a toposurface only. It is recommended that you create the building pad within a site plan. However, you can add a building pad to a toposurface in a floor plan view. The pad may not be immediately visible in the floor plan view if the view range or building pad offset are not adjusted appropriately.(see image)
Edited on: Wed, Mar 25, 2009 at 10:40:36 PM
Thanks. I just visited Typhoon video on the pad and he mentioned about not necessary to create a pad thickness when there is already aldb slab ....and i am understanding from all sources including yours is the pad is used to cut toposurface and therefore thickness is not necessa necessary...i figuring it out right now and see how far i can get to understand this. thanks again.
Cutting floor slab edges out of pads |
Mon, Oct 25, 2004 at 10:43:55 PM
Pad, slab, topo, LOST!! [ 1 2 ] |
Mon, Mar 30, 2009 at 4:17:38 PM
16
Building pad, what is it exactly? |
Mon, Dec 20, 2010 at 11:51:41 AM
14
Building Pad Problem |
Thu, Dec 20, 2012 at 3:51:09 PM
Building Pad |
Mon, Jul 12, 2010 at 12:30:01 PM
Members: | 2116731 | Objects: | 23197 | Forum Posts: | 152299 | Job Listings: | 3 |
