Forums >> Revit Building >> Technical Support >> Array association and relocation - please help
21 Posts No Rating |
I am trying to create a louver system with an array (obviously). To start i create the Louver as a Family and Nested it into the Main Louver Family. When i position and attached the object as a individual it locates and resizes the way i ask it too. But once i attribute an Array to this it messes it up completely and disassociates it to the attribute i attached it too. (i hope that made sense) I have created a Louver Array Integer to determine the amount to array. It seems to throw off my original Reference when an Array is applied. If someone can help i would very much appreciate it. I have attached the file so that you can see what has happened, and if you can resolve it, please let me know what you've done so that hopefully i wont have to deal with this issue again. Create in Revit 2008 (please stick to this)
There are some fully parametric wall louvers in the downloads that work fine. Perhaps it would be easier to grab one of those.
I would like to know how to do this properly. I don't want someone elses work. Who knows when i may run into this issue with something other than a louver and i would like to be able to resolve it. But thanks.
Hi, don't argue with WWhub, download and see the video: http://www.megaupload.com/?d=PLKWN5UD Sorry for the delay but I just see this thread a few minutes ago.... and I forgot to put here the model changed....LOL
Edited on: Thu, Mar 26, 2009 at 3:25:44 PM
Yeah still the Offset from Floor is messing up the Array... i think it might be with the Louver Nested Family that is causeing this issue. I'm going to attempt something! But thanks for your help, very much appreciated.
Hummm, I don't check ALL parameters, right now I don't have here Revit but when I can I take a look....
No, the problem is not in the nested family, it was simple, just "align" and "lock" the last element (bottom) with the ref. plane
I've got numerous tutorials out there on arrays. Checkout my blog. BY typically if its breaking in elevaiton than generally the nested family bottom reference is set to "not a reference". Change its "is reference" value to Bottom and then constrain by that in the host family. Always constrain nested families via their "defines origin" reference planes and you'll be fine! FOr any array 3D array there are 6 constraints that are needed: array to last: 1st element contrain in X, Y, & Z and last element constrain in X, Y & Z. array to second: 1st element contrain in X, Y, & Z and second element constrain in X, Y & Z.
Regards,
Chris.
Co-Founder | BIM Consultant | Software Designer B. Arch)
Thanks Mr Spot, as always your advice is very helpful, i will def. check out your blogs and go from there!
Array association |
Tue, Nov 11, 2008 at 9:17:32 AM
Array group association |
Sun, Nov 16, 2008 at 3:26:20 PM
Array on a Parametric Face |
Tue, Mar 7, 2017 at 5:09:11 PM
how can I array along spline? [ 1 2 ] |
Fri, Nov 28, 2008 at 7:07:33 AM
19
Array along a curved path |
Tue, Nov 11, 2014 at 9:11:46 AM
Members: | 2115393 | Objects: | 23192 | Forum Posts: | 152305 | Job Listings: | 3 |
