93 Users Online (91 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Box around text
Wed, Mar 25, 2009 at 11:21:58 AM | Box around text
FJ22
Hello,
I want to know if it's possible to create an automatic box around a text. So this jumps out of the drawing more than a usual text. Now I just draw detail lines but when i adjust the text I need to redraw or change the lines.
Thanks in advance for a solution.
Gr.
Frank
Tue, Jul 7, 2009 at 5:51:45 PM | Box around text
DannyG01
I just want to know how to turn the cursed thing off. It seems totally unnecessary as well as distracting. I'm an old draftsman, if it doesn't mean anything it shouldn't be on the drawing at all.
Edited on: Tue, Jul 7, 2009 at 5:53:10 PM
Wed, Jul 8, 2009 at 6:51:16 AM | Box around text
Danny - What is it you want to turn off?
Wed, Jul 8, 2009 at 9:26:09 AM | Box around text
DannyG01
I'm having trouble with these "boxes" showing up during our publishing cycle. These boxes don't appear on screen, and I couldn't find a toggle to turn on/off so I'm stumped as to why it shows up when plotting. It almost makes me think that that they are "shadow images."  I have the text settings set at 'Opaque' so that you don't get drafting lines going through text.
Wed, Jul 8, 2009 at 9:27:46 AM | Box around text
DannyG01
Could this be a Windows plotter driver problem?
Wed, Jul 8, 2009 at 9:42:19 AM | Box around text
It sounds like it's the masking region limits for opaque text.  I think it's a driver problem.  If you can't fix that ... try printing to a PDF then plotting the PDF.
Wed, Jul 8, 2009 at 9:49:44 AM | Box around text
DannyG01
Wierd thing is, not everyone is having this same issue. That makes me think that this is probably a local printer issue; I just haven't had time to prove it yet.
Thu, Aug 13, 2009 at 4:50:07 PM | Box around text
tuomoto
I am having the same issue. altho the weird thing is that my first plot is fine but my subsequent plots have boxes around the arial text. this also only happens for the 11x17 print size. this is very annoying and the only solution i have come up with is opening each sheet and printing them one at a time.
Changing Text Size in a text box
Thu, Aug 6, 2009 at 6:41:14 AM
text box
Wed, Jan 7, 2009 at 4:47:43 PM
Text with surrounding box
Fri, Oct 3, 2008 at 12:39:43 PM
Text Box Size
Tue, Jan 27, 2015 at 4:23:26 PM
text box leader alignment
Sun, May 9, 2010 at 7:48:45 AM
Page generation time: 0.5973
