43 Users Online (42 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> Newbies >> Revit MEP 2009 - Vertically stacked devices (families) overlapping
Wed, Mar 25, 2009 at 10:23:00 AM | Revit MEP 2009 - Vertically stacked devices (families) overlapping
hprovins
i was wondering if there is a solution for vertically stacked items that appear on the same wall. ex: wall receptacles that are directly beneath one another but at different elevation heights. on the plan view it appears the receptacle symbols are overlapping each other, and it becomes a mess. when you offset the symbol off the wall, the 3D model follows it creating an incorrect elevation view. basically, the rough-in view of the wall box is following the 2D view of the symbol.
any way around this?
-howard
p.s. ive tried creating a parameter called "symbol offset" and using a dimension bewteen the 2D symbol and a reference plane, but the symbol still automatic snaps to a wall and will not leave the surface it is mounted to. when you go to offset it, again the 3D model follows
Wed, Mar 25, 2009 at 2:58:57 PM | Revit MEP 2009 - Vertically stacked devices (families) overlapping
hprovins
nvm. i found a solution. the symbol was an 'annotation' i had to edit the family that the actual symbol was bound to. adding an offset parameter for the symbol alone was the key. this may help anyone that designs rough-ins and has the challenge of populating condense areas or places where devices stack vertically. thanks for the help P
Sat, Jun 20, 2009 at 3:40:21 AM | Revit MEP 2009 - Vertically stacked devices (families) overlapping
osdrafting
Find below given link about vertically stacked partitions:
http://revittut.blogspot.com/2006/10/vertically-stacked-partitions.html
Let me know if it can be os any help.
Revit MEP 2011 crashes when circuiting electrical devices.
Thu, Jan 27, 2011 at 9:27:58 AM
vertically stacked walls
Wed, Jan 26, 2005 at 8:48:43 PM
No NUrsecall Familes In revit Mep 2010??
Tue, Oct 22, 2013 at 12:37:01 PM
ID Numbers and Unasscoiated Families In Revit MEP
Tue, Nov 29, 2011 at 12:12:18 PM
Devices Moving IN Model
Tue, Dec 6, 2011 at 1:47:25 PM
Page generation time: 2.0316
