46 Users Online (43 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Choppy Handrail / stringer joints
Wed, Mar 25, 2009 at 10:18:14 AM | Choppy Handrail / stringer joints
naterfisher
4.5 Stars: 3 Votes
I am trying to have my handrails and stringers connect with each other smoothly in a custom stair set. If you see the attached image you will see what I mean when you look at how my handrails connect with each other at different portions of the curved stair some parts of the handrail seem stepped up slightly from the conneting portion of the handrail.  Also the image with monolithic stair set selected I cannot have the underside of the winder show up smooth even when I select that option in the stair properties.
 I am going to try modelling these stairs in 3 parts.  The 2 straight runs and then the curved portion, perhaps this will solve some problems but I do not think this is the correct way to do these stairs.
Thanks for any help,
 Nate
Wed, Mar 25, 2009 at 11:00:25 AM | Choppy Handrail / stringer joints
tim123
4 Stars: 19 Votes
I would model the stairs in three parts.
It would appear from your post that the side walls to the stairs are stringers.  Rather do them as rails, the bottom rail being a wall.  You can then use a similar rail for the landings.  You will have more control over how they interact.
STAIRS - Stringer & Handrail Cut
Mon, Nov 1, 2010 at 8:06:54 PM
Cleaning up a handrail/ stringer join
Sat, Nov 26, 2016 at 1:04:26 AM
Stair Stringer connections
Wed, Jan 14, 2015 at 11:14:39 AM
Stringer Haunch (level off) at top of flight
Wed, Dec 14, 2011 at 2:03:06 PM
Handrail without Balusters
Wed, Oct 2, 2019 at 4:04:39 PM
Page generation time: 0.2236
