15 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> Spline from AutoCAD to Revit
118 Posts No Rating |
I tried to search for this topic and wasn't able to find a perfect solution. The question is: How do you trace or pick the spline imported from AutoCAD? Thanks in advance.
Create the Spline in Autocad, then import that spline file to Revit, pick in that, in the options bar you have "Full Explode" button, pick in that then you can "play" with your spline....
Very cool. Thanks a lot, it works. You are the man.
Sorry, another question. After the full explode, how come I can't pick it anymore when I tried to create a wall?
Because Revit don't allow to create wall with a spline, you don't have that option like you can see in the image attached, if you want tho create a wall to follow the spline then use the "create in Place" in the category "Walls" and create and extrusion with that shape OR create a Mass then Apply Wall by face...
There it is wall by face....
![3.5 Stars: 7 Votes](/images/stars_3.5.gif) |
If you are using the geometry to create something like say...a slab edge...you can import the cad drawing while in the slab creation mode and it will automatically pick it.
Cool man. It works again. So the trick is to create a mass of the spline line from AutoCAD. Then create the wall off the face of the mass. Thanks once again.
spline with two heights? |
Tue, May 12, 2015 at 8:08:32 AM
Annotation the Radii of a spline? |
Fri, Apr 23, 2010 at 9:53:44 PM
How to make closed spline |
Wed, Jul 20, 2016 at 8:41:23 AM
associative spline |
Fri, Nov 7, 2008 at 7:47:39 AM
3D Multi-planar Spline Sweep with Adaptive Family |
Fri, Mar 21, 2014 at 3:23:47 PM
Members: | 2026030 | Objects: | 22991 | Forum Posts: | 152208 | Job Listings: | 3 |
