82 Users Online (81 Members):
Forums >> Revit Building >> Technical Support >> Extruding Logo into mass
32 Posts No Rating |
I have a fairly complicated company logo that I would like to cut out of a metal panel that is being hung on a building. Any ideas on how/if that can be done? I didn't know if there is a way to extrude a mass from an image and then cut it out as a void from a solid mass. I'm not getting my hopes up about it, but if it is possible, it would be excellent. Thanks in advance. (I'm using 2009)
Edited on: Tue, Mar 24, 2009 at 11:42:29 AM
As long as you can describe the shape with linework in sketch-mode, it can be extruded as a positive or negative. But it can not be an image....
![4 Stars: 19 Votes](/images/stars_4.gif) |
Do exactly as you suggest, but I would use a generic model rather than massing. If there is text in the logo you'll have to use a workaround as you cannot create void model text.
This is the logo: http://profile.ak.facebook.com/object3/447/10/l23983837457_3518.jpg I'm not sure I'm following. Do I need to trace it, then extrude?
"I have a fairly complicated company logo" - Hummm I don't think so.... Use the Extrusion, i think i create that in a "Generic Model Face Based" or "Wall Based"....
Edited on: Tue, Mar 24, 2009 at 2:09:35 PM
That's Finished... The text is "Model Text"...
URGENT! blue logo revit 2012 |
Fri, Jun 14, 2013 at 9:45:05 AM
Offset face of Mass = possible? |
Tue, Jan 21, 2014 at 2:06:18 PM
Logo / Filled region in Drawing Sheet |
Fri, May 7, 2010 at 4:22:30 PM
Logo on a Titleblock showing up in negative |
Wed, Oct 31, 2012 at 7:49:50 AM
JPG logo |
Wed, Mar 20, 2013 at 7:40:52 AM
Members: | 2022486 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
