105 Users Online (104 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Rendered Colors Don't Match
Tue, Mar 24, 2009 at 10:13:57 AM | Rendered Colors Don't Match
jmbitzer81
I have a Conc. wall w/ RGB Colors 196-189-172 and I have a CMU wall adjacent to it w/ the same 196-189-172 color. When I run it through the rendering engine, the Conc. wall is much darker than the CMU.  I know that shade & shadow will darken the image up, but the walls are on the same plane and facing the camera. Any suggestions?
Tue, Mar 24, 2009 at 10:19:20 AM | Rendered Colors Don't Match
tim123
4 Stars: 19 Votes
Can you upload a screenshot?  It may be the surface texture - or smoothness of the material.
Tue, Mar 24, 2009 at 10:24:43 AM | Rendered Colors Don't Match
jmbitzer81
The CMU Walls are to the left and right, and the Conc. wall has 2 colors, a dark one, and a lighter one to match the CMU.
This was done on Revit Architecture 2009 Medium Grade 150DPI.
Tue, Mar 24, 2009 at 10:56:59 AM | Rendered Colors Don't Match
tim123
4 Stars: 19 Votes
Can't see much from the PDF - do a quick rendering showing only the area where the contrast can be seen (use screen, high - should go faster than printer - 150dpi).
Tue, Mar 24, 2009 at 12:53:40 PM | Rendered Colors Don't Match
jmbitzer81
I think I figured it out. The Conc. had 'weathering' set to be automatic, which made it a lot darker than the CMU block.  By changing it to none, the colors matched when rendered.
Thanks
RGB Colors Don't Match
Mon, Jan 4, 2010 at 2:47:44 PM
Room Colors don't show in R2010
Thu, Aug 13, 2009 at 11:38:19 AM
Compent colors don't show up in renderings
Tue, Apr 24, 2007 at 12:54:18 PM
colored/rendered plans
Fri, Jan 9, 2009 at 5:44:24 AM
Numerate 'Sheet Number' parameter for match line family
Mon, Apr 28, 2014 at 10:17:51 AM
Page generation time: 2.3407
